Go Back   Club3G Forums > Performance & Tech Forums > Forced Induction & Nitrous > RS/GS
Old 07/02/2007, 12:05 PM   #1 (permalink)
Soon to be boosted..
virtuaframax's Avatar
Vehicle: Eclipse GS '01 - Sporty
virtuaframax : who are you?virtuaframax : who are you?
Virtuaframax Turbo Project
As stated in the title, another turbo project.
First of all I have to thank all you turboed guys (particularly NAPALM, BENZ01GS, GSKNIGHT, CloudINC00, Chief Brody, XwP1ayawX, DNS-EN, and BALLA for their threads, posts, replies and comments).
I have been reading the FI section since I joined the club and definitely learnt a lot… I finally decided to start piecing together my turbo project… started getting the basic things. I will run 8psi on stock internals.
But here is my list of things (I loved the way Benz01 layout to show his turbo project, so I will copy that):
TURBO, MANIFOLD AND IC:
* EVO 8 Turbo - Bought Uninstall
* Forge Adjustable Actuator -
* Megan Racing Evo 8 Manifold - Bought Uninstall
* RRE SS Angled Spacer - bought
* Evo 8 Ported o2 Housing - Bought Uninstall
* Ebay FMIC: 28x7x2.5 – 2.5” – Bought Uninstall
* Evo 8 LICP + Custom IC piping from Universal Kit 2.5” – Bought Uninstall
* Top Fuel BOV with pipe - Bought Uninstall
* DEI Heat Wrap - Bought
EXHAUST:
* EVO VIII Downpipe - Bought uninstall
* GReddy EVO 2 CB 2.5"– Bought Installed
* Catco HFC – Bought Installed
* Weld on Wideband Bung – Bought uninstalled
OIL/COOLING:
* Oil feeding and drain lines –
* New Oil pan, gasket and sealant -
* Oil Sandwich from filter - Bought and installed
* Fitting for Oil line on pan -
FUEL/IGNITION/ELECTRONICS
* NGK Spark plugs (1 range colder) –
* Magnecore Spark plugs wires – Bought installed
* WRX 440cc injectors – Bought
* New o-ring for fuel Injector - Bought
* Autometer A1000 + fitting –
* Walbro 255 FP – Bought Uninstalled
* AEM UEGO WB – Bought Uninstalled
* Autometer Digital EGT gauge (52mm) - bought
* AEM Tru-Boost gauge (52mm) - Bought
* Emanage Blue– Bought
* Emanage Support tool - Bought
* Boomslang Harness -
* Tactrix Cable - Bought
* EVOScan – Bought and working
* ECUFlash – Bought and working
* GM MAF - Bought
* MAF-T -
MISCELLANEOUS:
* New gaskets, bolts, nuts (copper) - Bought Uninstall
* The Bible: "Maximum Boost: Designing, Testing and Installing Turbocharger Systems" – Bought
* Red vacuum lines – Bought
* KYB AGX - Ordered
* Blox Vacuum manifold - Bought
* Speedhut 3 gauge pillar (52mm) - bought
I am planning on doing the install myself (with a friend) starting on a Friday night and hopefully finishing it on Sunday. By the time of the install everything will be already tested for fittings and measurements (cutting, welding, measuring each part will be done thru the next months during the weekends) so that it will be a true bolt on.
Since my car is a Sporty, the tuning will be initially thru a piggyback (Emanage) for the parts i cannot manage with ECUFlash... once the Airtek rom will be cracked... emanage in the trash!
Please feel free to give any suggestion and comment on parts I choose. Add anything I forgot and ask questions, cause I am still a newbie and no matter how much I read the threads, I am always learning something new.
Once again thanks to everyone!
Fra
virtuaframax is offline   Reply With Quote
Old 07/02/2007, 02:15 PM   #2 (permalink)
GSKNIGHT's Avatar
Vehicle: 02 sherwood green GS
GSKNIGHT seems to be okayGSKNIGHT seems to be okayGSKNIGHT seems to be okayGSKNIGHT seems to be okayGSKNIGHT seems to be okayGSKNIGHT seems to be okayGSKNIGHT seems to be okayGSKNIGHT seems to be okay
Looks like you've got a really good handle on things.
You'll be tuning with EcuFlash, correct?
GSKNIGHT is offline   Reply With Quote
Old 07/02/2007, 02:24 PM   #3 (permalink)
cyberbrain's Avatar
Vehicle: 08 Jeep JK 4x4
cyberbrain seems to be okaycyberbrain seems to be okaycyberbrain seems to be okaycyberbrain seems to be okaycyberbrain seems to be okaycyberbrain seems to be okay
Send a message via AIM to cyberbrain
why use the emanage blue???? It wont work with the ecu on the timing and 440;s can easily be flashed into the ecu??? just curious.
cyberbrain is offline   Reply With Quote
Old 07/02/2007, 02:32 PM   #4 (permalink)
I'll use ECUflash, but im not that good at it yet, so just in case i wont be on top of ecuflash by the time i do the install, i can at least tune with the emanage...
Old 07/02/2007, 02:52 PM   #5 (permalink)
toogood11's Avatar
toogood11 : who are you?toogood11 : who are you?toogood11 : who are you?toogood11 : who are you?toogood11 : who are you?
ah you should have maybe given the new aem fuel/ignition controller a shot instead of an emanage. i think im going to save up for one and see how well it holds up to an emanage/emanage ultimate.
just another n00b watching n00bs even MORE DUMB than myself blowing their shit up one start up at a time.
toogood11 is offline   Reply With Quote
Old 07/02/2007, 07:37 PM   #6 (permalink)
GT35 pimpin
XwP1ayawX's Avatar
Vehicle: 00 GS-T, 07 Yamaha R6
Ooooooh I got a thank you
Old 07/02/2007, 09:00 PM   #7 (permalink)
ace79603's Avatar
Vehicle: 2001 RS M/T & 2000 GS M/T
ace79603 seems to be okayace79603 seems to be okayace79603 seems to be okayace79603 seems to be okayace79603 seems to be okayace79603 seems to be okay
Send a message via AIM to ace79603 Send a message via MSN to ace79603 Send a message via Yahoo to ace79603
hey good luck Virtua
ace79603 is offline   Reply With Quote
Old 07/05/2007, 08:10 AM   #8 (permalink)
i have a question regarding the BOV since i havent chosen one yet...
firts of all: should i have my BOV recirculated? the answer i gave myself is yes... (even if i wont have the nice hissing sound).
the second questrion is: if the answer to my first question is yes, at this point i dont need anything fancy and i guess i can go with a stock 1G or 2G BOV, right? or should i get a brand name?
Old 07/05/2007, 09:16 AM   #9 (permalink)
steadly2004's Avatar
Vehicle: Stratus 2.4L
The big thing with the BOV is whether its before or after the MAS. If you're using a suck through... most common.... then the air has already been measured and when you vent to the atmosphere the car thinks it is getting more air than it is and will run rich.
However if you are using a blow through/speed density or something like that, you can vent to the atmosphere. If blow through, you must vent before it hits the MAS.
*note* you shouldn't blow through our MAS, and if you wanted to do that, you could use a GM MAF, with a thranslator*
The type of BOV is up to you, I just wouldn't suggest getting anything that is an E-bay knockoff. I mean, either get an 1g/2g oem or a brand name BOV. Thats my opinion, take it as such.
Old 07/05/2007, 09:52 AM   #10 (permalink)
hey steadly2004, thanks a lot for ur answer... thats exactly what i thought... im going for the suck through set up... thats y i knew i had to do a recirculated BOV...
i remember reading about the GM MAF and translator in case of a blow thru setup...
Old 07/05/2007, 02:12 PM   #11 (permalink)
Yea, I am using the Blow through... I just like the idea of metering it after it has been through the intercooler and changed temperature.
And I am glad to hear that you have read up on the subject.
Old 07/05/2007, 03:53 PM   #12 (permalink)
do u have any idling problem?
Old 07/07/2007, 03:23 PM   #13 (permalink)
question on the floor: whats ur advice for a turbo gauge? i kinda find myself debating between the AEM tru-boost gauge and an autometer... i leaning towards the AEM since i have already have the UEGO... SUggestions?
Old 07/07/2007, 06:26 PM   #14 (permalink)
3GwithVOLKS's Avatar
3GwithVOLKS : who are you?3GwithVOLKS : who are you?3GwithVOLKS : who are you?3GwithVOLKS : who are you?
I'd stay away from autometer unless it is a mechanical gauge. They have a tendency of being inaccurate. I have the Greddy 60mm peak/warn gauges and couldnt be happier. They are big enough to read clearly, can set a warning light to come on once the desired boost is reached so you can back off, and when your done you can press a button and see what the highest level of boost was.
3GwithVOLKS is offline   Reply With Quote
Old 07/07/2007, 06:54 PM   #15 (permalink)
ace79603's Avatar
there is a guy selling an HKS bolw off valve for 125 I belive
Old 07/08/2007, 04:07 PM   #16 (permalink)
I thought that once the desired boost is reached, the wastegate should open up and prevent it from boosting past that level? Meaning you shouldn't have to let off?
Oh, and with the AEM guages, I went with all AEM, after purchasing the wideband. And when I got the boost guage, I got the combo that is a controller also, since the difference in price is equal to that of a manual boost controller. Then I purchased the oil pressure, it was either that or EGT, but I only have a 3 guage pillar pod, and don't want to loose one of my AC vents. I don't know if the clock pod would work, since my dash is different from the eclipse.
its still in the shop, I'll have to let you know once I get it back. I was too pussy to do my own install.
Old 07/08/2007, 06:43 PM   #17 (permalink)
The GLR 4x4
3gEclipseRS's Avatar
Vehicle: 04 Dodge Ram
3gEclipseRS seems to be okay3gEclipseRS seems to be okay3gEclipseRS seems to be okay3gEclipseRS seems to be okay3gEclipseRS seems to be okay3gEclipseRS seems to be okay3gEclipseRS seems to be okay
Send a message via AIM to 3gEclipseRS
Sorry to temporarily hijack the thread. How much is it costing you right now to do the install on your car? Im looking having a shop install mine,and was reading this thread for info.
3gEclipseRS is offline   Reply With Quote
Old 07/08/2007, 07:16 PM   #18 (permalink)
well, it isn't done yet, but coming out to approximately.....3000 labor (including dyno tune), 1000 parts (repurchased stuff that didn't work out).... 500 timing belt labor and associated parts...... 500 new motor mounts, custom fabricated and installed.
It would have been another 500-800 if I could have come up with the cash for a custom mandrel bent cat back exhaust, but for now its 3" down to the cat, and a crappy crush bent 2.5" cat and everything back from it.
I had quite a few cheaper offers, but this shop was the cleanest most reputable shop I could find to do the install. They are all ASE certified mechanics and AEM trained tuners. check out my thread.
Sorry about the thread jack, if you have any more questions for me, direct it to my thread:
Steadly's turbo talk
Old 07/08/2007, 10:26 PM   #19 (permalink)
3000 for the installation??? that sounds pretty pricey... since ure giving them all the parts... im gonna install it myself with a couple of friends... we're gonna start friday night and try to have everything done by sunday... however, we dont wanna rush... by the time of the installation, everything we'll be figured out and measured... so we should be good!
Old 07/09/2007, 10:49 PM   #20 (permalink)
boost creep or boost spikes. it happens. More common with internally gated turbos. For example. My wastegate opens at 7psi and then creeps up to 15-20psi by redline. I need to stop being lazy and install my tial.
Old 07/09/2007, 10:55 PM   #21 (permalink)
thats something i didnt know about internally wastegated turbos... i might just change my setup and get an external wastegate with a small T3 then... i though internally wastegated turbos were pretty safe on that!
Old 07/10/2007, 08:04 AM   #22 (permalink)
I hope your install goes smoothly. I haven't had my car for almost 6 weeks... but it'll be worth it. GOOD LUCK! and keep us updated.
Old 07/10/2007, 12:25 PM   #23 (permalink)
it might not happen to you. That is just what happens to be and also some of my dsm friends it has happened to. You can still use a 16g and use an external wastegate. That is what I am doing and I have seen another member on the boards do it.His set up it looks like he welded a flange to the manifold and did it that way. With mine, my downpipe already has the downpipe and wastgate dump divorced. So, what i am going to do is use a little piece off of the wastgate dump mount the tial on it, and then im finally going to resirculate the wastegate back in the downpipe cause the open dump has gotten annoying.
Old 07/10/2007, 09:31 PM   #24 (permalink)
thanks man... the installation doesnt scare me too much... what im more concern about is the first tune... i hope i will be able to have it running decently right away and then day by day fine tune it...
Old 07/10/2007, 09:37 PM   #25 (permalink)
I Deliver Porsches
4G64TT's Avatar
4G64TT sucks4G64TT sucks
if you dump the O2 it takes care of boost creep...
4G64TT is offline   Reply With Quote
Old 07/11/2007, 12:08 PM   #26 (permalink)
really? mine is dumped and it still crteeps from 7psi to 15-20psi. and i have had 2 different mitsu wastegates on it
Old 07/12/2007, 11:48 AM   #27 (permalink)
Kuztom Uzer Tytel
Benz01GS's Avatar
Vehicle: '04 Lancer Evolution RS
Benz01GS : who are you?Benz01GS : who are you?Benz01GS : who are you?
Send a message via AIM to Benz01GS
NOICE, you seem to have been doing your research.
A+
BUY MY SHIT!!!
"Save your money, and do it right."
Benz01GS is offline   Reply With Quote
Old 07/12/2007, 05:26 PM   #28 (permalink)
thanks Benz... might change the turbo to an EVO8 if i get a good deal... we'll see
Old 07/17/2007, 09:42 AM   #29 (permalink)
well... as u can see, i got a good deal on a brand new EVO 8 Turbo... so i chaged my set up to that...
do u know if any mitsu wg actuator work on the EVO8?
Old 07/17/2007, 09:49 AM   #30 (permalink)
toogood11's Avatar
you need a evo 8 specific wastegate acuator for that turbocharger.
if you bought it brand new, it SHOULD come with an acuator on it already.
Old 07/17/2007, 10:24 AM   #31 (permalink)
Its brand new, but the guy i bought it from i guess removed it. My question is: can i use any actuator from a EVO3 turbo?
Old 07/17/2007, 11:23 AM   #32 (permalink)
Kuztom Uzer Tytel
Benz01GS's Avatar
I've never heard anything about that... You could take it as an opportunity to buy a brand new FORGE wastegate actuator, or change it from an internally gated to externally gated set-up.
BUY MY SHIT!!!
Old 07/17/2007, 11:30 AM   #33 (permalink)
Kuztom Uzer Tytel
Benz01GS's Avatar
Don't forget the Exhaust manifold flange that you'll need for the Evo VIII Manifold... ground down to 1/8" on top, and 3/8" on bottom
BUY MY SHIT!!!
Old 07/17/2007, 12:33 PM   #34 (permalink)
toogood11's Avatar
dude, i just answered this. you need a evo 8 specific wastegate acuator for that turbocharger.
its very obvious if you just look at the acuators, you can tell they mount differently.
Old 07/17/2007, 06:15 PM   #35 (permalink)
i found a EVO 8 actuator set at 12 psi... i think im just gonna get that and mount it on the turbo.
toogood11: thanks for the answer... i didnt know that since ive always been looking at the EVO3 set up and suddenly i came across a EVO8 turbo and didnt want to miss the deal! thanks for the info
Old 07/17/2007, 06:20 PM   #36 (permalink)
toogood11's Avatar
no problem. i think the stock setting on evo's is 12psi? but i may be wrong. keep up the progress.
Old 07/17/2007, 06:30 PM   #37 (permalink)
it is 12 psi... so i might have to get a boost controller or just get the AEM Tru Boost Gauge, that allows to change the boost
Old 07/20/2007, 10:20 PM   #38 (permalink)
i have a question for you guys...
will i need a turbo o2 housing with the EVO VIII turbo? im pretty sure i will, ut ive never noticed it on the setups... anybody can help?
Old 07/20/2007, 11:10 PM   #39 (permalink)
Kuztom Uzer Tytel
Benz01GS's Avatar
yes, as long as you'r using the internal wastegate and evo dp, you will need the 02 housing.
BUY MY SHIT!!!
Old 07/21/2007, 10:04 AM   #40 (permalink)
perfect... thats what i thought... i have the internal wastegate (actuator) and ill probably pick up a evo dp somewhere...
Old 07/25/2007, 07:47 AM   #41 (permalink)
i was thinking of picking up a EVO oil pan so that i dont have to mess with drilling and fittings... it should be a bolt on, right? i mean, it should be the 4G64 pan. am i correct?
Old 07/25/2007, 04:19 PM   #42 (permalink)
Kuztom Uzer Tytel
Benz01GS's Avatar
yes, but you'll also need the pickup as well. That's the reason I didn't buy it.
BUY MY SHIT!!!
Old 07/25/2007, 07:47 PM   #43 (permalink)
I Deliver Porsches
4G64TT's Avatar
if you are wanting an evo 8 downpipe i got one ill sell ya... i picked it up with the evo exhaust i bought...
Old 07/25/2007, 10:09 PM   #44 (permalink)
how much for it shipped to 60302? and is it new or used?
Old 08/08/2007, 11:22 AM   #45 (permalink)
heres the latest purchase:
it looks sweet... what do u guys think?
Old 08/08/2007, 11:44 AM   #46 (permalink)
Kuztom Uzer Tytel
Benz01GS's Avatar
I like it, but take pictures of the actual one when you get it...
You'll have to take a bit off the top of the runners, and bend it up enough (I think about 10-15*) in order to clear the starter. Then go and get it rewelded.
Like I said in my thread, it'll end up costing significantly less, and look significantly better than the OEM Evo mani. Make sure you come up with a good way to keep it from cracking, though.
BUY MY SHIT!!!
Old 08/08/2007, 01:09 PM   #47 (permalink)
RandomEclipse's Avatar
Vehicle: 01 GS
RandomEclipse : who are you?
Cracking was what i was worried about
but damn that looks sweet
hope it holds.
RandomEclipse is offline   Reply With Quote
Old 08/08/2007, 03:10 PM   #48 (permalink)
i bought last night, so ill receive hopefully by the ned of the week and for sure at that point i will start taking some pics of all the parts i accumulated so far...
as soon as ill receive it i will start testing the fitment and realize what needs to be done...
ill keep u posted guys!
Old 08/08/2007, 03:40 PM   #49 (permalink)
GS-Turbooo
CloudINC00's Avatar
CloudINC00 seems to be okayCloudINC00 seems to be okayCloudINC00 seems to be okayCloudINC00 seems to be okayCloudINC00 seems to be okayCloudINC00 seems to be okayCloudINC00 seems to be okayCloudINC00 seems to be okay
change those gaskets though.
Cloud: 2003 GS-T
ZeroType.org
CloudINC00 is offline   Reply With Quote
Old 08/08/2007, 10:46 PM   #50 (permalink)
i was thinking of getting copper gaskets for eveything if i can find them!
Old 08/14/2007, 09:19 PM   #51 (permalink)
heres what i got in the mail today... absolutely nice...
Old 08/14/2007, 09:28 PM   #52 (permalink)
beautiful
Old 08/14/2007, 09:47 PM   #53 (permalink)
I Deliver Porsches
4G64TT's Avatar
seems like a few people are doing the exact same setup lol...
i have the same megan manny but black.
Old 08/14/2007, 10:32 PM   #54 (permalink)
GT35 DOHC 500wHp
slava's Avatar
Vehicle: 3G turbo
slava seems to be okayslava seems to be okayslava seems to be okayslava seems to be okayslava seems to be okayslava seems to be okay
Looks nice when new . Enjoy.
slava is offline   Reply With Quote
Old 08/16/2007, 04:05 PM   #55 (permalink)
it looks all shiny and clean... and absolutely gorgeous!!!
Old 09/01/2007, 02:22 PM   #56 (permalink)
Here are some pics of the parts collected so far...
AEM UEGO Wideband
Evo VIII Turbo and actuator
Top Fuel BOV
Walbro 255
the IC is in the car and i didnt feel like going to get it...
Old 09/01/2007, 02:25 PM   #57 (permalink)
using the spacer to clear the starter, will i need longet exhaust studs? i think i will, but im not sure if these will be long enugh:
www.ssstuds.com
its the set for the 2G with the two 10M studs for the sides and copper nuts...
Let me know guys before i buy them!
Old 09/01/2007, 11:59 PM   #58 (permalink)
GSKNIGHT's Avatar
www.ssstuds.com
They already sell an extended stud kit. Just tell them what you are doing, and they will know what to give you.
Good luck.
Old 09/02/2007, 09:51 PM   #59 (permalink)
trip's Avatar
Vehicle: 01 Eclipse GS-T
trip : who are you?trip : who are you?
nice work man nice to see someone in chicago area doing this too, im in the middle of this project too stuck on the tuning and spacer for now, pm me if u need any help
trip is offline   Reply With Quote
Old 09/05/2007, 10:19 AM   #60 (permalink)
just ordered the extended stud kit with copper nuts... waiting to receive the o2 housing and evo dp and then its fitment time!!!!
Page generated in 1.47001791 seconds (100.00% PHP - 0% MySQL) with 11 queries
