Jstewart92's Custom Retrofitted Headlights (pic heavy) - Club3G Forum : Mitsubishi Eclipse 3G Forums
Go Back   Club3G Forum : Mitsubishi Eclipse 3G Forums > Non-Performance Car Forums > Show and Shine
Old 11/15/2011, 04:34 PM   #1 (permalink)
Retrofitter
jstewart92's Avatar
Vehicle: 03' Eclipse GS
jstewart92 seems to be well-liked by alljstewart92 seems to be well-liked by alljstewart92 seems to be well-liked by alljstewart92 seems to be well-liked by alljstewart92 seems to be well-liked by alljstewart92 seems to be well-liked by alljstewart92 seems to be well-liked by alljstewart92 seems to be well-liked by alljstewart92 seems to be well-liked by alljstewart92 seems to be well-liked by alljstewart92 seems to be well-liked by all
Send a message via Yahoo to jstewart92
If you've been following me on facebook you've already seen many of these pictures, but here's my official build thread. I assume that the opinions on them will be somewhat polarizing, but I like it. Also, my car is dirty as heck, deal with it.
Parts:
FXR 2.0
Morimoto 35w ballasts (not newest gen)
HD harness
Philips 85122+ bulbs
MCR shrouds
X-pel headlight film
I didn't want to go crazy with the mods so I kept it nice and simple
Mods:
CCFL to shine through shroud
Aqua colored demon eye
Color matched housing
Color matched 'Daytime' demon eye
I spent about a good 2 weeks (on and off) doing everything up to finish it, finally. Don't plan to do the FX-R again, at least not the way that I did it this time (with brackets) so we'll see if I produce any others of these. I do however still plan to do retrofits with the mini D2S or H1.
Here's my story, with some of the pictures I snapped along the way (some are crappy cell pictures)
My car is T19, steel blue pearl, I did the daytime demon eye to match the car. I also used the JNC method to mount the projectors.
What I started with:
What was on my car (H1 6k HIDs in Halogen projectors - CCFL halos)
I had some confusion in finding my proper alignment on the reflector, red indicates what I marked off of the reference lines, I was worried I didn't have straight forward, but I wound up sticking with my original markings and will use the headlight aiming to fix the forward aiming.
After I had the projector mounted in the reflector it looked like this:
This is my "professional" paint booth. Lay down something to keep paint from getting on the lid, paint your part, then place the rest of the container over top.
Paint:
I went back and forth on the color combination I wanted on the lights, I think my final decision will be somewhat polarizing.
As you can see I already painted my reflector gloss black. That left the headlight shroud and the projector shroud to be painted. For the headlight shroud I was picking between Gloss black, flat black, or color matched. For the shroud I was trying to decide between chrome or a smoked chrome appearance.
Headlight stripped of chrome (gloss black plastic) and the chrome shroud
I then decided to color match the headlight shroud.
I really liked how the shroud stuck forward just enough to get past the headlight shroud and be able to shine straight out of the headlights.
After seeing this I wanted to tie in my grille/fake vents and turn signals a little better, so I went with a smoked chrome shroud. I used Duplicolor metalcast smoke on the shroud, and decided to keep the inner ring of the MC-Rs chrome. After initial painting and before adding clear to the metalcast paint.
I then took this picture to see what the headlight would look like with the shroud as is:
I then decided I needed to add some clear coat to the shroud to bring out a more defined shine.
Before and after clear coat:
Clear coated shroud is on the right.
Demon eye and CCFL
Shrouds attached.
On the 13th I wired up the demon eye and put the new harness in, made it as plug and play as possible.
Here's some installed photos. I'm neglecting to take close up shots because I kinda flubbed the lens film up, mainly on the driver's side, just not used to having to use a heat gun to apply film, but I did much better with the second light.
I've managed to get the demon eye pretty bright being that this shot was daytime, albeit in shade.
CCFL + demon eye
I'll get some output shots eventually, I've been really tied up with these, school, work, and the finishing details with timster's lights. I will say that they are very nice, even at 35w, if I decide I'll want brighter lights I'll go with 50w ballasts, as the OEM bulbs can take that added power. I will say, I believe the high beam can blind poor little birdies. Unfortunately I can tell that these projectors (while replicas) were originally designed for an SUV (because the high beam is indeed so far up). But even though these are the short-lived 2.0s and my first REAL retrofit, I'm quite pleased with the end result.
UPDATE:
I wanted to compare the Sonar output with these tonight, but I have a quiz tomorrow morning so sorry, but it's more important to study
So these shots were the best I could do with my limited photography knowledge, I tried to get the mixture of brightness and color as accurate as possible, but I couldn't get it to be the exact same. F4.0, 1/6, ISO 800.
Wall shots taken at about 30 feet from wall. The reason for the downfall of the short-lived 2.0s is rather evident, luckily for everyone but myself TRS has begun selling a hybrid 1.1 instead, which should have a straighter cutoff.
Looking back over these, the brightness is exaggerated, and the color is cooler than what it should be, the lights appear to be 5k, but they're 4.3k... maybe the white wall had something to do with that?
jstewart92 is offline   Reply With Quote
Old 11/15/2011, 04:37 PM   #2 (permalink)
Retrofitter
jstewart92's Avatar
More pictures will be coming.
Old 11/15/2011, 04:43 PM   #3 (permalink)
Protect this house
ccarrillo717's Avatar
Vehicle: Yes
ccarrillo717 - if you don't know me, you must be newccarrillo717 - if you don't know me, you must be newccarrillo717 - if you don't know me, you must be newccarrillo717 - if you don't know me, you must be newccarrillo717 - if you don't know me, you must be newccarrillo717 - if you don't know me, you must be newccarrillo717 - if you don't know me, you must be newccarrillo717 - if you don't know me, you must be newccarrillo717 - if you don't know me, you must be newccarrillo717 - if you don't know me, you must be newccarrillo717 - if you don't know me, you must be new
Like I said on FB love it! definitely one of a kind
ccarrillo717 is offline   Reply With Quote
Old 11/15/2011, 04:45 PM   #4 (permalink)
USN
Vehicle: 2004 Eclipse RS
3G Runner has a few friends here3G Runner has a few friends here3G Runner has a few friends here3G Runner has a few friends here3G Runner has a few friends here3G Runner has a few friends here3G Runner has a few friends here3G Runner has a few friends here3G Runner has a few friends here3G Runner has a few friends here
Looks real good.
3G Runner is offline   Reply With Quote
Old 11/15/2011, 04:49 PM   #5 (permalink)
Shut up.
wright06jhs's Avatar
Vehicle: 2007 Infiniti G35X
wright06jhs has a few friends herewright06jhs has a few friends herewright06jhs has a few friends herewright06jhs has a few friends herewright06jhs has a few friends herewright06jhs has a few friends herewright06jhs has a few friends herewright06jhs has a few friends herewright06jhs has a few friends here
Send a message via MSN to wright06jhs
Looks awesome!
07G35x|Premium|15%tint|HKS|Zwheels|TopSpeed|BC BR Coils|
My Ride
G35Driver
wright06jhs is offline   Reply With Quote
Old 11/15/2011, 04:49 PM   #6 (permalink)
Retrofitter
jstewart92's Avatar
And that was the idea!! I wanted to make these lights were different enough so that someone who knew nothing about the 3g would be able to tell that those were not stock, or aftermarket headlights.... per se
Originally Posted by 3G Runner View Post
Looks real good.
Thanks! I also did it a lot for the safety aspect as well, got tired of the Sonar output with HIDs in them, not to mention the crappy quality when compared to the stock (stanley) lights.
Old 11/15/2011, 04:53 PM   #7 (permalink)
Mattt is recognized club-wideMattt is recognized club-wideMattt is recognized club-wideMattt is recognized club-wideMattt is recognized club-wideMattt is recognized club-wideMattt is recognized club-wideMattt is recognized club-wideMattt is recognized club-wideMattt is recognized club-wideMattt is recognized club-wide
Nice work! How much $?
Mattt is offline   Reply With Quote
Old 11/15/2011, 04:56 PM   #8 (permalink)
mitsu3g01's Avatar
Vehicle: 01 GS
mitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regularmitsu3g01 should be considered a regular
If i need anything i will contact you in the future.
mitsu3g01 is offline   Reply With Quote
Old 11/15/2011, 05:01 PM   #9 (permalink)
Retrofitter
jstewart92's Avatar
Originally Posted by wright06jhs View Post
Looks awesome!
Thanks brosky!
Umm retail for the parts list alone (not including mounting hardware, lights, etc.) is about $450 if you added the $50 for the film used (which included covers for fogs and turns)
Old 11/15/2011, 05:07 PM   #10 (permalink)
black3gks's Avatar
Vehicle: 2000 eclipse gt
black3gks : who are you?black3gks : who are you?black3gks : who are you?
WOW! these are sick man! how bout you repaint the housings black and ship em out to me haha jk jk
black3gks is offline   Reply With Quote
Old 11/15/2011, 05:11 PM   #11 (permalink)
timster2833's Avatar
Vehicle: '03 Eclipse GTS
timster2833 has a few friends heretimster2833 has a few friends heretimster2833 has a few friends heretimster2833 has a few friends heretimster2833 has a few friends heretimster2833 has a few friends heretimster2833 has a few friends heretimster2833 has a few friends heretimster2833 has a few friends heretimster2833 has a few friends here
Originally Posted by jstewart92 View Post
Thanks brosky!
Now you gotta put film on mine lol
timster2833 is offline   Reply With Quote
Old 11/15/2011, 05:27 PM   #12 (permalink)
finesse49ers's Avatar
Yeah, we'll definitely be doing business in the future.
This is what I'm about: The 3G, 1998 GSX, EVO IX GSR.
Originally Posted by kevin711 View Post
Originally Posted by PharmEcis View Post
finesse49ers is offline   Reply With Quote
Old 11/15/2011, 05:30 PM   #13 (permalink)
REDLINE ALL GEARS
thahnic1080's Avatar
Vehicle: 2002 GT SDS
taking it to another level. Looks good
thahnic1080 is offline   Reply With Quote
Old 11/15/2011, 06:03 PM   #14 (permalink)
Drewski0523's Avatar
Damn man. Those look great.
Drewski0523 is offline   Reply With Quote
Old 11/15/2011, 06:08 PM   #15 (permalink)
jaloosk's Avatar
sexy. +rep/
jaloosk is offline   Reply With Quote
Old 11/15/2011, 06:13 PM   #16 (permalink)
Photoshopper
grfft3r's Avatar
Vehicle: 2001 Black Eclipse GT
grfft3r seems to be well-liked by allgrfft3r seems to be well-liked by allgrfft3r seems to be well-liked by allgrfft3r seems to be well-liked by allgrfft3r seems to be well-liked by allgrfft3r seems to be well-liked by allgrfft3r seems to be well-liked by allgrfft3r seems to be well-liked by allgrfft3r seems to be well-liked by allgrfft3r seems to be well-liked by allgrfft3r seems to be well-liked by all
I love it! These are very unique and well done. I'll be hiring your services in the future too. My darn sonars keep fogging up
grfft3r is offline   Reply With Quote
Old 11/15/2011, 06:29 PM   #17 (permalink)
soundman98's Avatar
soundman98 is well-liked by manysoundman98 is well-liked by manysoundman98 is well-liked by manysoundman98 is well-liked by manysoundman98 is well-liked by manysoundman98 is well-liked by manysoundman98 is well-liked by manysoundman98 is well-liked by manysoundman98 is well-liked by manysoundman98 is well-liked by manysoundman98 is well-liked by many
i'm really not feeling the color-matched housings, or that shroud design-- though i like what you did with the shrouds-- just enough chrome to make 'em shine, but not enough to mirror the world..
and i doubt most here know the 'JNC method'... (psst-- check hidplanet ) any intentions for jnc's rainbow cutoff mod?
edit--your hid planet account still has the old pic
The never-ending project, my '01 Spyder GT
more projects then time!
when 'bright' reverse lights don't cut it
exterior led upgrades--75% (led tails, turns, third brake, plate light, reverse light)
interior led upgrades--10% (gauges and hvac next, dome light completed)
whats next? ford raptor(for the lightbar!!)..
soundman98 is offline   Reply With Quote
Old 11/15/2011, 07:27 PM   #18 (permalink)
Shit happens...
ToqirM's Avatar
ToqirM has a few friends hereToqirM has a few friends hereToqirM has a few friends hereToqirM has a few friends hereToqirM has a few friends hereToqirM has a few friends hereToqirM has a few friends hereToqirM has a few friends hereToqirM has a few friends hereToqirM has a few friends here
I don't know why but I expected the ccfl to be a lot more visible during the day. Good job with the project though. I really like it.
ToqirM is offline   Reply With Quote
Old 11/15/2011, 07:30 PM   #19 (permalink)
Got Rice Boy's Avatar
Vehicle: 2004 WRX
Got Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by allGot Rice Boy seems to be well-liked by all
They look pretty damn visible in my opinion. The CCFL is the dots around the projector lens...just so you know.
Got Rice Boy is online now   Reply With Quote
Old 11/15/2011, 07:39 PM   #20 (permalink)
Shit happens...
ToqirM's Avatar
Lol I know that I'm not blind, I was referring to the volume of light that shows from each dot.
Old 11/15/2011, 07:59 PM   #21 (permalink)
2011's are gay
White Knight's Avatar
Vehicle: 03 Eclipse GTS 6G75
White Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by all
those are fucking sexy
White Knight is offline   Reply With Quote
Old 11/15/2011, 08:28 PM   #22 (permalink)
Ken
Shocker Lite
Ken's Avatar
Vehicle: RX350
Ken should be considered a regularKen should be considered a regularKen should be considered a regularKen should be considered a regularKen should be considered a regularKen should be considered a regularKen should be considered a regularKen should be considered a regularKen should be considered a regularKen should be considered a regularKen should be considered a regular
Send a message via AIM to Ken
Nice! Keep up the good work
Ken is offline   Reply With Quote
Old 11/15/2011, 10:01 PM   #23 (permalink)
Retrofitter
jstewart92's Avatar
Thanks for all the replies guys, for some reason I guess I wasn't expecting so many people replying and being so positive.
I didn't expect as many people to like the color matched housings as there is. I like it color matched, and I think a lot of the reason for that is that the headlight and turn signal are separate from each other, in addition to the very visible housing. And I copy pasted most of the writing from my oter build thread on hidplanet. The shroud paint was a bit of a test, since I never used metalcast paint before, and not many people wrote reviews on that color as it's relatively new.
Don't intend to anything more to the projectors themselves. Mainly due to the plight of the 2.0s.
The shroud is actually a 3 piece shroud, there's a frosted lens that the CCFL sits behind, it's not an entirely clear lens so some brightness is lost in it... As with any CCFL, they're only visible in direct daylight somewhere between 100-200 feet, but they kill common LED halos. Saw a lot of turned heads today and yesterday (had the CCFLs on as i drove around)
I will say I love the light output. It's still taking a little getting used to with seeing the cutoff on the ground in front of the car, but the output is great, I promise. I drove home tonight on the highway, not only did I notice that as I drove in the fast lane passing people I could see a line from my lights going through theirs and casting on the curb to the right of them as I passed. Also as I drove in the slow lane I saw my beam being cast on the curb on the far side of the street, across 4 lanes. We'll see when I get pictures of it my friends.
Old 11/15/2011, 11:34 PM   #24 (permalink)
Guru of Rice!!!!!!
rsingh12's Avatar
Vehicle: YOUR MOM
rsingh12 seems to be well-liked by allrsingh12 seems to be well-liked by allrsingh12 seems to be well-liked by allrsingh12 seems to be well-liked by allrsingh12 seems to be well-liked by allrsingh12 seems to be well-liked by allrsingh12 seems to be well-liked by allrsingh12 seems to be well-liked by allrsingh12 seems to be well-liked by allrsingh12 seems to be well-liked by allrsingh12 seems to be well-liked by all
Send a message via AIM to rsingh12
looks like shit nothing but ricer mods lol
rsingh12 is offline   Reply With Quote
Old 11/15/2011, 11:37 PM   #25 (permalink)
TROLL KING
treehead's Avatar
treehead seems to be well-liked by alltreehead seems to be well-liked by alltreehead seems to be well-liked by alltreehead seems to be well-liked by alltreehead seems to be well-liked by alltreehead seems to be well-liked by alltreehead seems to be well-liked by alltreehead seems to be well-liked by alltreehead seems to be well-liked by alltreehead seems to be well-liked by alltreehead seems to be well-liked by all
those turned out amazing, I love the color matching you did
MY CAR
treehead is offline   Reply With Quote
Old 11/16/2011, 06:58 AM   #26 (permalink)
2010s are gay!
Daniel Shawfe's Avatar
Daniel Shawfe seems to be okayDaniel Shawfe seems to be okayDaniel Shawfe seems to be okayDaniel Shawfe seems to be okayDaniel Shawfe seems to be okayDaniel Shawfe seems to be okayDaniel Shawfe seems to be okayDaniel Shawfe seems to be okay
Oh wow, those are awesome! I never liked the single projector in the housings though, it looks lonely.
But +1 because they're still super awesome!
Sabrina
Daniel Shawfe is offline   Reply With Quote
Old 11/16/2011, 10:30 AM   #27 (permalink)
Ken
Shocker Lite
Ken's Avatar
Vehicle: RX350
Output pics?
Old 11/16/2011, 10:36 AM   #28 (permalink)
Aple juic is my beer
drunkoffjuic's Avatar
Vehicle: 02 GT 3.8L, 07 Jeep GC
drunkoffjuic is one of the reasons this club existsdrunkoffjuic is one of the reasons this club existsdrunkoffjuic is one of the reasons this club existsdrunkoffjuic is one of the reasons this club existsdrunkoffjuic is one of the reasons this club existsdrunkoffjuic is one of the reasons this club existsdrunkoffjuic is one of the reasons this club existsdrunkoffjuic is one of the reasons this club existsdrunkoffjuic is one of the reasons this club existsdrunkoffjuic is one of the reasons this club existsdrunkoffjuic is one of the reasons this club exists
Send a message via AIM to drunkoffjuic
Great job......Interested in maybe doing some business with ya....
Members Ride
drunkoffjuic is offline   Reply With Quote
Old 11/16/2011, 01:03 PM   #29 (permalink)
Retrofitter
jstewart92's Avatar
I might get some output pics tonight after class. Not sure if the wall I'm thinking about will be good for it, we'll see. If anyone is wanting a price quote or something feel free to leave me a visitor message on what you may want, or post what you want in my Custom Headlights thread, and I'll PM you a quote. My inbox stays at or above 90% so that's why I like to send the quotes myself.
Old 11/16/2011, 04:19 PM   #30 (permalink)
GT35 Monster
XwP1ayawX's Avatar
Vehicle: V-ROD, R6, GST
I just came
Old 11/16/2011, 08:17 PM   #31 (permalink)
Retrofitter
jstewart92's Avatar
I added wall shots, but I'm not real satisfied with the realism of the photos. :/
Old 11/16/2011, 08:34 PM   #32 (permalink)
Shit happens...
ToqirM's Avatar
They should use your car for the next iron man movie. Lol.
Old 11/16/2011, 11:19 PM   #33 (permalink)
Your Reality Check
ICEMAN99TURBO's Avatar
Vehicle: Y2K GT-P
ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.ICEMAN99TURBO paypaled $25 to ED for this rep.
Send a message via AIM to ICEMAN99TURBO Send a message via Yahoo to ICEMAN99TURBO
Very cool....
ICEMAN99TURBO is offline   Reply With Quote
Old 11/17/2011, 12:58 AM   #34 (permalink)
MIAGT's Avatar
Vehicle: Topless e46
MIAGT : who are you?MIAGT : who are you?MIAGT : who are you?MIAGT : who are you?MIAGT : who are you?
Love it, Love it, Love it! Retrofits FTW!
MIAGT is offline   Reply With Quote
Old 11/17/2011, 09:56 PM   #35 (permalink)
soundman98's Avatar
.....and your addicted as much as i dislike my d2s retro, it hits on the same points, and makes me happy when i can use it at night.. just like my reverse lights.. though the bixenon is just as much fun when i get to flash the people with 10000k pnp kits(i admit, i keep my finger on the stalk always looking for someone to flash)
Old 11/17/2011, 10:06 PM   #36 (permalink)
Retrofitter
jstewart92's Avatar
Haha, I've been itching at the chance to flash someone, these highbeams are unlike anything I've seen. I want RX330 projectors..
Old 11/18/2011, 01:23 AM   #37 (permalink)
bwracing00's Avatar
Vehicle: 2000 Eclipse GS-T
bwracing00 has a few friends herebwracing00 has a few friends herebwracing00 has a few friends herebwracing00 has a few friends herebwracing00 has a few friends herebwracing00 has a few friends herebwracing00 has a few friends herebwracing00 has a few friends herebwracing00 has a few friends herebwracing00 has a few friends here
Send a message via AIM to bwracing00 Send a message via Yahoo to bwracing00
not a bad setup they look great.
2000 Eclipse GS-TURBO
GI CF hood
KYB/Tein s-techs
Custom Body Kit
18" HP evo lightning
Custom skyline taillights
Carbon Fiber interior
http://i208.photobucket.com/albums/b.../bwracing2.png
bwracing00 is online now   Reply With Quote
Old 11/22/2011, 10:33 PM   #38 (permalink)
Fuck salt.
JermTheElf's Avatar
Vehicle: 2005 LGT
JermTheElf seems to be well-liked by allJermTheElf seems to be well-liked by allJermTheElf seems to be well-liked by allJermTheElf seems to be well-liked by allJermTheElf seems to be well-liked by allJermTheElf seems to be well-liked by allJermTheElf seems to be well-liked by allJermTheElf seems to be well-liked by allJermTheElf seems to be well-liked by allJermTheElf seems to be well-liked by allJermTheElf seems to be well-liked by all
Send a message via AIM to JermTheElf Send a message via Skype™ to JermTheElf
Such a sexy build!
They're going in the subie
http://www.club3g.com/forum/image.php?type=sigpic&userid=20908&dateline=128778  2130
My Eclipse
You can enjoy your straightaways; I prefer the turns.
JermTheElf is offline   Reply With Quote
Old 11/26/2011, 11:30 AM   #39 (permalink)
Retrofitter
jstewart92's Avatar
Thanks!
Originally Posted by JermTheElf View Post
Such a sexy build!
I remember talking to you about this on FB some, didn't see your post here. Are you doing RX330 low beam, or the bi-xenon version?
