Taillight troubles - Club3G Forum : Mitsubishi Eclipse 3G Forums
Go Back   Club3G Forum : Mitsubishi Eclipse 3G Forums > Non-Performance Car Forums > Show and Shine
Old 02/08/2012, 08:44 AM   #1 (permalink)
teh_nexus : who are you?
Taillight troubles
I've got an 01 Spyder, and it seems I have an electronic issue going on with my one light. I thought the bulb just burnt and swapped it out for a fresh one, but it still doesn't want to light up. If I hit my brake it does, hazards work, and backup's all come on, but just turning on my headlights doesn't light up the main light or the one on the back fender. Someone said it might be my relay, but I'm really not sure so I'm coming to the experts on this before I go take it to a shop and drop big bucks.
teh_nexus is offline   Reply With Quote
Old 02/08/2012, 09:05 AM   #2 (permalink)
outrageousgt's Avatar
Vehicle: 01 gt eclipse
outrageousgt : who are you?
Check all your fuses.
Sent from my iPhone using Tapatalk
outrageousgt is offline   Reply With Quote
Old 02/08/2012, 09:22 AM   #3 (permalink)
From what I saw the fuses looked good, then again I really wasn't sure which fuse to be looking at in that
Old 02/08/2012, 11:42 AM   #4 (permalink)
FeelsGoodToBeGangsta
Gangsta_Man's Avatar
Vehicle: 2001 GTP
Gangsta_Man has a few friends hereGangsta_Man has a few friends hereGangsta_Man has a few friends hereGangsta_Man has a few friends hereGangsta_Man has a few friends hereGangsta_Man has a few friends hereGangsta_Man has a few friends hereGangsta_Man has a few friends here
I would clean out the metal bulb housings and grease them with electrical anti-corrosive grease, probably some corrosion going on there.. And also make sure it's the right type of bulb. It has to be a dual filament type
Please wait while I attempt to care...
Gangsta_Man is offline   Reply With Quote
Old 02/08/2012, 01:22 PM   #5 (permalink)
I made sure it was the right bulb when I grabbed it, someone warned me about the dual filament. I cleaned out the housing when I pulled the bulb but I didn't grease it or anything like that.
Old 02/08/2012, 01:35 PM   #6 (permalink)
patriotred01's Avatar
patriotred01 : who are you?patriotred01 : who are you?
If both the rear side marker and the tail light bulb are not working, the problem lies farther up. Possibly a short or a break in the wire.
patriotred01 is offline   Reply With Quote
Old 02/08/2012, 07:22 PM   #7 (permalink)
Go baby go!! :lol:
soundman98's Avatar
soundman98 has a few friends heresoundman98 has a few friends heresoundman98 has a few friends heresoundman98 has a few friends heresoundman98 has a few friends heresoundman98 has a few friends heresoundman98 has a few friends heresoundman98 has a few friends heresoundman98 has a few friends here
i've long since given up on checking specific fuses-- the one i never check is always the one burned out.. check all of them
The never-ending project, my '01 Spyder GT
more projects then time!
when 'bright' reverse lights don't cut it
exterior led upgrades--75% (led tails, turns, third brake, plate light, reverse light)
interior led upgrades--10% (gauges and hvac next, dome light completed)
whats next? ford raptor(for the lightbar!!)..
soundman98 is offline   Reply With Quote
Old 02/09/2012, 07:41 AM   #8 (permalink)
I went over both fuse boxes and everything looked good to me, I'm banking at this point for a break or something in the wires
Old 02/09/2012, 02:49 PM   #9 (permalink)
Vehicle: 2001 GTP
The wire you would need to check would be the green wire with a white stripe.
Do your gauges work? If yes the the break is somewhere between the kick panel where all the wires are, and along the drivers side rocker panel to the tail light.
Also can you be a bit more specific? I'm assuming from what i can understand the problem is the parking lights don't come on in both tail lights and both side marker lights?
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
