new project = s13?
Need help ASAP!
Well I have the front of my car lowered and when I moved to the back to take the struts off, the bottom bolt came off but the strut wouldn't budge at all. I read everything and tried the hammer and chiesel, deep creep, and today I took it to a shop and they couldn't get it. The guy said it was rusted on and I might have to cut it. I haven't tried to torch it yet however. If i cut it then could i just get another bolt the same size and have a shop put the bolt on then go back and change out the struts?
heres a pic of the dragracer ![]() ![]()
Waiting to spool
Vehicle: 01 Gt
I'd get a torch on there first and see what you can do. When working with rusty bolts heat is your best friend.
Eclipse tuners are a strange sort. They don't like talking about wings or color-matching side skirts and interiors. Eclipse tuners are performance-obsessed sleeper fanatics who dream only about downpipes, exhaust gases, and wastegates. Their cars aren't pretty, but have the ability to spank you silly on the highway. |
Waiting to spool
Vehicle: 01 Gt
Hairdryer more than likely isn't going to get hot enough, unless it's like a super dryer.
![]() Do you have a pic of the bolt that is stuck?
Vehicle: 08 IS350
I know people have problems getting the strut to slide off and they end up cutting the ring part of the strut. I was lucky and mine slid right off.
#8 (permalink) | |
keep working at it, me and my friend thought we were boned back there too until we got lucky and persistence got it done.
new project = s13?
Ok, so the bolt I have in my hand comes off but the strut and bushing will not come off the little bar on the inside since it's rusted and what not. I tried the hairdryer and PB blaster and everything today. Tomorrow I am taking it to a guy that can torch it.
Waiting to spool
Vehicle: 01 Gt
Can you get a pry bar and wedge it in there and pry it off? I think that's what I used on a friends cavalier. It was a while ago though, so I don't remember exactly.
Waiting to spool
Vehicle: 01 Gt
You sure? If you got a long pry bar inbetween the shock bottom and the metal rod it touches you could be able to get enough force to pry it off there.
#14 (permalink) | |
torch will work.
The first pics you posted remind me of this white integra around town that rolls around with the front damn near scraping and its rear way up
Hopefully I don't run into the same problem as you when I go to install my new setup when it gets a little warmer around here. I can already see the car is going to look great with those wheels and the drop.
#17 (permalink) |
Titanium Spork
Vehicle: 2001 spyder gs
looks like a job for an air hammer, and pickle fork.
you got questions? we got answers: http://tearstone.com/shop/Factory-Service-Manuals/ |
#18 (permalink) |
^ Yep. Or the torch. Or cutting it with a Dremel. Basically it's brute force that does it, whichever path you go.
This is really common. I'd consider closing the thread since it's one of those things that *has* been asked a ton of times. But it's somewhat entertaining so it'll stay open... |
#19 (permalink) | |
new project = s13?
#23 (permalink) | |
hey now, those hairdryers can get pretty hot.
![]() possibly a heat gun could cook the bushing out of there...but you'll still need to get the crap off the stud that the strut goes onto.
#24 (permalink) |
Ph.D > me
Vehicle: '04 TSX ; '07 G35x
We used an angle grinder to cut off the bottom part of the ring and even then, part of the rubber bushing was still seized to the shaft. We then used a dremel with some high grit sandpaper to remove the bushing remains. After that, we put ANTI-SEIZE onto shaft before installing the new shocks.
#25 (permalink) |
*Photoshop Bitch*
Vehicle: 2000 GT
Yup, I had the same issue way back when Sam and I were swapping suspensions. Tried everything under the sun in our power to no avail. Took it to a shop, put it on a lift, and tried a pry bar with a 7 foot pipe with no luck. The only thing left was to torch the bushing, and then you could work on the inner "sleeve" with various tools. I think we put a pair of vice grips on there and were able to break it free.
And I did drive back with the bushing torched. Just took it slow and careful since the rear shock was in pieces at that point. Figured it would be fine for a one way trip and replacing the shock as soon as I got back to Sam's place. |
#34 (permalink) |
Titanium Spork
you got questions? we got answers: http://tearstone.com/shop/Factory-Service-Manuals/ Last edited by scarr; 02/16/2010 at 09:22 PM. |
#38 (permalink) |
Titanium Spork
yeah, that is an old muscle car term, for when you jack the rear in the air for big meats back there... like a stinkbug.
| Thread Tools | |
