Rear lower control arm/toe adjusting bar bushing question
I know this may seem like a noobish question and I've searched, but can't find a answer. I need a bushing for my right rear lower control arm where it connects to the crossmember. Does the energy suspension and/or polyurethane bushing kits come with a bushing that would fit? Also, my car is a 03 GTS.
Thanks in advance for any help!
fortune favors the bold. |
Design Engineer
I didn't want to start a new thread but I too need a pair of bushings for the rear toe control arms. Anyone know where I can buy a pair?
I tried napa, autozone, and advance auto and this is the only thing that comes up in autozone search: Rear control arm bushing But I dont know if any of these will fit in the TOE control arm because I think those once are supposed to be shaped like a sphere or a ball. Edit: Also, does the ball joint have to be removed to replace the bushing?
"A pedestrian hit me and went under my car" Last edited by ShowStoppinGT; 08/24/2010 at 06:52 PM. |
#5 (permalink) | |
CreepnIn The Shadows
I've got an energy suspension kit at work. I'll take a look tomorrow to see what exactly it came with. There's a bunch of bushings for the front and rear.
Design Engineer
Well it looks like you're right, you can't just buy the bushings. Unless you bought the whole set and got lucky with finding one that fits. How much did you end up paying for it at the dealer? Did you take it to a shop... if you did how much did they charge you for labor?
My local dealer is asking $74 per control arm. And I found this website who's selling them for $57: JNZ Tuning Rear Control Arm $57.02 Is anyone familiar with this website or the quality of their parts? Their customer service seems very friendly, quick to respond, and give plenty of information on anything that you ask...
"A pedestrian hit me and went under my car" |
I got it for about $75 at the dealer. No junk yard in town had one in good condition. I actually installed it myself when I was doing my struts, it was a piece of cake compared to the rear struts. It's like literally one bolt and one nut you have to remove.
Design Engineer
I really want to do it myself too but what scared me is when I went to the junkyard to remove the same control arm from a 00 eclipse gt so that I can remove the bushing, but the nut was so seized onto the bolt that when I turned it, it broke the bolt! I'm afraid the same thing will happen to me and I dont have a cutting tool to cut the bolt if it breaks.
Thats one thing, another is that I don't have a ball joint separator, nor any tools to put it back in. I might only damage the new ball joint by hitting it with a hammer trying to push it in... then I'll spend another $80 to have it towed to a shop cause I got stuck half way
#10 (permalink) | |
Check out this part number from energy suspenion 5.3128R That is the rear control arm kit. It might have what you need.
#11 (permalink) | |
I would just suggest taking it to a shop if you don't think you can do it then. I would just suggest soaking it down the night before with PB blaster if you do decided to do it.
There are no after market bushings for those arms. The bolt on the subframe can be a pain and may need to be cut out. Order new bolts for them. They are a special bolt.
On the ball joint side, just tap it with a hammer and it will come out. As for the new one, you shouldn't run into any issues getting the nut to tighten down. It fits in the hole rather tight and keeps it from spinning while tightening. You will need a rear alignment after you get done because your rear toe will be off. |
#13 (permalink) | |
Design Engineer
I'll still order new bolt/washer/nut, I just don't want it to break halfway through because I dont own any cutting tools.
Vehicle: 2000 GS
If i remember correct, you can get the Megan rear trailing arm.
Mitsu Eclipse 1995-2005 Megan Racing Rear Trailing - WeSellCarParts.com It is adjustable. |
#19 (permalink) |
Vehicle: 2000 GT
Oldish post, but does anyone know if this will fit a 2000 GT? It looks the exact same.
95-04 ECLIPSE Left Rear Toe Control Arm Genuine OEM - eBay (item 150550296606 end time Feb-16-11 09:19:11 PST) And what a price... |
#20 (permalink) | |
Titanium Spork
Vehicle: 2001 spyder gs
you got questions? we got answers: http://tearstone.com/shop/Factory-Service-Manuals/ |
#22 (permalink) |
The part number for the one in the ebay listing is MR124293.
2G Eclipse used MR124293. 3G Eclipse 2.4L used MR124293 & MR162571. I don't know what the difference is between those are. They are both driver side. 3G Eclipse 3.0L used MR325255. Driver side. |
#24 (permalink) |
Just the tip
Vehicle: 02 stratus R/t
I have a 3.0 , dealer wanted 75 apeice paid I think 47ish. I saw that eBay link, that's a good price, but it is also for. 2.4 not a 3 liter. I had searched eBay and found none when I was buying mine. There are a $hit ton of parts for the 2nd gen eclipse( and cheaper), than the 3rd gen. At that there's even less for the stratus. Every part I have is made for the eclipse.
#25 (permalink) | |
Vehicle: 2000 GT
#27 (permalink) | |
Vehicle: 2000 GS
JNZ website showed that GS and RS are using different arm as their price are different. |
#28 (permalink) | |
GS MR162571 GT & GST MR325255 I don't know why RS and GS would use different arms and why GT and GST would use different arms than RS and GS. Maybe there's a difference in the cross members? |
#31 (permalink) |
There is no difference between any of the 3g rear ends besides the fact that the RS doesn't come with a sway bar. It is however, easily added. Sway bars, bushings, etc are all interchangeable across the trim levels, while I have no actually looked under an RS or GS in awhile, my memory says they looked no different.
#32 (permalink) | |
Vehicle: 2000 GT
![]() Any chance you know if the 2g and 3g rear suspension is interchangeable across the different trim models? (Minus the GS-T I believe..) |
#33 (permalink) | |
Vehicle: 2000 GS
My 0.1 cent though. |
#36 (permalink) |
Vehicle: 03 GTS 3.6L 6g74
FWIW I have a complete 2g rear bushing kit on my 03 GTS. I am sorry but I replaced them all a couple of years ago and it is fuzzy but I have both prothane and energy. One of the kits does not come with bushings for one of the rear arms but I liked something about that kit better so I mixed and matched. I think one of the kits was graphite injected (black if you are dealing with energy) and the other was not.
I am a mechanic with access to a lift, endless shop tools, press cup combinations etc. It was still a PITA. I would not recommend this if you care about noises, vibrations and ride quallity but otherwise it is awesome. It allowed me to soften up my shocks a little but it planted the rear where as it would oversteer before in a momentum slide very easilly. I also have noticed better tire wear. My tires used to be more choppy and wear very uneven but now wear flat across the whole tire even though I run extremely aggressive alignments and drive the car really hard. |
#38 (permalink) |
I know a lot of people are still trying to figure this out(including me) so I want to contribute what knowledge I have of the subject.
If you have a GT/GTS eclipse there is no bushing currently offered The arm from the 2g eclipse is different than that of a GT/GTS 3g. I am not sure what the exact differences are but I am certain the diameter of the bushing is considerably smaller. According to winCAPS and oemmitsubishi, the 2g FWD model shares the same arm as the 4 cylinder 8g galants and 3g eclipses. That being said, The only way to have a bushing and be able to use it on your GT/GTS would be to swap the arm with the one from a 2g eclipse or a 4 cylinder 3g eclipse. Now I Know most of this information is already known but I wanted to sum it all up and hopefully get a solid answer/solution to this problem. I will be heading to the junkyard this weekend to pull the arms off a 2g eclipse. Then I will be able to post up pictures of the 2 and what not, If everything checks out I will be ordering new OEM arms for the 4 cylinder 3g. Is there anyone that has a 4 cylinder 3G that can take a picture of the arm? Last edited by Beriant; 03/15/2011 at 06:19 PM. |
#40 (permalink) |
Read my post 4 above this one. If you buy a rear bushing kit for a non awd 2g it will work on any 3g. The same is true for 2g rear shock mounts fitting on a 3g. I know this information because I bought a 2g kit and installed it on my 03 GTS myself. Like I said in the post above I bought both 2g and 3g kits. The 2g kit came with way more bushings.
I vaugely remember the round lower control arm that goes from the subframe out to the bottom of the trailing arm being different between the two kits. Not in diameter but in length of the bushing. The 2g bushing would press in the arm but when you went to bolt the arm in the car it was much narrower than where it bolts into the subframe. I installed it at first and did not figure out it was wrong until I tried to bolt it back in the car. It was a couple of years ago so I could be completely wrong about this but do know that you can MOST DEFINITLY replace ALL the rears if you just buy both kits. It seems like the least hassle also because both kits are fairly cheap. Go here and scroll to the very bottom of the page and cross reference the #'s with energy suspensions part#s. I found this page VERY helpfull when I was researching this. Road Race Engineering's Eclipse Suspension Upgrades Bottom line though there are off the shelf poly bushings for nearly every bushing on the whole car between the 3g and 2g kits. Last edited by GSXROFDFW; 03/19/2011 at 01:36 PM. |
#41 (permalink) |
Not to be a dick but you are wrong. There is no bushing made for the GT/GTS Toe arm.
The 2G kit does come with A LOT more bushings than the 3G kit and you will still need it in order to have your whole rear suspension bushings replaced with poly bushings. There are 3 differences in the 2G and 4 cylinder arms and the GT/GTS arms. 1. The hole for the bushing is considerably smaller in diamater 2. The hole for the bushing on one side has a raised lip that is part of the arm it self 3. The 4 cylinder/2G arm weights a lot less than the GT arm, there is metal welded underneath the arm to add weight to it. I took one for the team and bought both the GT/GTS and GS/RS arms brand new from the dealership. And for those of you who are wondering the 2G rear control arm kit does have the correct bushing for 3G GS/RS toe arm. Here are the pics. ![]() ![]() ![]() ![]() ![]()
#43 (permalink) |
Forgive me...I was looking at the wrong arm. I was thinking of the straight tubular control arm straight out from the crossmember. It even says toe adjustment arm in the title so my fault sorry.
#44 (permalink) | |
3G World Traveler
Vehicle: 2003 Eclipse 2.4L
If life sucks..drive faster. Last edited by RogueTune03; 04/12/2011 at 10:22 AM. |
#45 (permalink) |
Vehicle: 2001 eclipse gt
Energy Suspension Control Arm Eclipse 00-04 | eBay
so i came across these just wondering if they have been verified to fit the gt/gts yet? |
#46 (permalink) | |
3G World Traveler
Energy Suspension Control Arm Bushings [Part#: 5.3128R] http://catalog.rpmware.com/catalog/item/101814
If life sucks..drive faster. |
#47 (permalink) |
PROTHANE 00-05 MITSUBISHI ECLIPSE REAR CONTROL ARM BUSH - eBay (item 360327110399 end time May-08-11 18:26:16 PDT)
there are these too from prothane it looks like there are more bushings in this set |
#48 (permalink) |
Vehicle: 2000 RS / GS mix
I want to buy prothane bushings, and I want to upgrade/replace my whole rear suspension.
so I thought about the GT control arms. my eclipse is a RS, but planning to swap a 6g74 someday. is it comfirmed that there are bushings for the control arm? |
#49 (permalink) |
The only real difference between the 2g and 3g rear suspensions is the lower control arm that attaches straight out of the crossmember. There are people on DSMTuners putting our rear suspension in there cars as they are interchangeable. The one thing is the sway bar must match the lower control arm, 2g to 2g and 3g to 3g as the end link locations are different. That said, I don't know if a 2g bushing kit will have the right lower control arm bushing. I also don't know why you guys are complaining about interchangeability when we have a bushing kit available (THANKS TO ME FOR BUMPING PRODUCTION LAST FALL) for our rear ends, and it is good for ALL TRIM MODELS. To put a sway bar on an RS you simply have to drill holes for the sway bar and put in GT control arms.
#50 (permalink) |
As for Beriant's toe arm thing he posted earlier. I would still keep the GT arms. Why? That lip is far more important then you think. The bushing itself is smaller in diameter while the interior pin remains the same, so there is less room to flex, it is more rigid. Furthermore that lip means the bushing itself is longer, and even more rigid as it won't flex side to side or in and out because the force it more spread out. And no, that metal on the 2g arm wasn't welded in for weight, light suspension parts are a GOOD THING, it was welded in for rigidity. Instead of dealing with that flimsy POS they made a single stamped piece out of heavier gauge steel for the 3g, even more reason to keep the GT arm. Though I'd be highly surprised if anyone in creation pushed either arm to their limits, except for a drunk moron who ran a curb at 55 last week. Mitsubishi was not into downgrading when they made the 3g, all the tweaks they made gave it a superior suspension setup then the 2g, it just happened to come with soft ass springs/struts and bushings.
Cliff notes? Use the GT arms, they are BETTER. |
#51 (permalink) | |
but I also want the right prothane bushings. look my point is simple. I am from holland, and all this stuff isn't available here. so I need to import everything from the USA. when I am replacing the stuff I want to have all the parts I need at home, cause otherwise I have to wait about a month to get the bushings and I can go further with my replacements. so for me it is all not as easy as you think. that's why I want to know for sure which bushings I need with the GT control arms. |
#53 (permalink) | |
so that is why I want to import everything I need at once. than I can do the job on my car without leaving it for a month cause I have to wait at parts. I'm planning on the following - Wheel hubs Timken - GT lower control arms - Prothane bushing kit (to replace as much bushings as possible) - ST sway bar - D2 coilovers - Moog endlinks - DC rear strutbar is there anything else you would recomment? |
