Rear Tire Wear "Bumps" in the inside
Hello
Car: 2003 Eclipse GS Miles: 94,000 To Summarize: * Struts have less then 20,ooo miles * Tires have less than 15000 miles * I have a camber kit * Alignment Tests come green. Problem: Rear tires have "bumps" in the inside Tires: Nankang NS-II 225/40/R18 PSI: 42 front/back I purchased the vehicle with 78,000 miles three years ago and the tires were in pretty good condition when I bought it from the dealer. I was given a 30 day warranty so I took it to a mechanic for a complete check up. The mechanic told me that the rear struts were bad so they were replaced by the dealer. I have the Konig Unknown 18 inch rims and they do add some road noise but after a few months of purchasing the vehicle I was washing my car and noticed that the rear tires had "bumps" in the inside of the tire. Other than the bumps, the rear tires are in pretty much brand new condition, is just the inside "bumps". I took it to a local tire shop and I was told I needed a camber kit and that was going to fix it. I decided to get the camber kit along with 4 brand new tires and got it aligned, by this time the car had around 84,000 miles. Everything went fine but after a few months and less than 5,000 miles the same thing happened to the rear tires. This time I took it to Tire kingdom and Firestone to test the alignment and everything came out green. I rotated the tires yesterday and even though the car runs straight I know the tires in the rear now are going to get the "bumps" too and now the road noise in the front is pretty loud at 80+. I would like to figure out what could be the problem before I purchase a new set of tires. Has anyone had/has this problem? I searched around and most of the issues are related to the front. Here's apicture but is hard to see, I had to pass my hand over to feel the bumps. Left: facing out | Right: facing inside ![]() Thanks for your help. |
Holy christ, 42 psi? That's your problem. You've blown them up so much that daily driving conditions is stretching the cords or something interior to the tire itself. Just because they're low profile doesn't bode 40 psi on the street, maybe for chasing cones but not otherwise.
Why rear and not front? The rear has very little weight on it and that means the tire that makes up the contact patch with the road is under much more tension making it more susceptible for road damage. With the front the weight presses the tire into the road which actually relieves tension in the contact patch. This is essentially the same concept as overfilling your tires at the track but longevity spun instead of handling issues. |
#3 (permalink) | |
Vehicle: 2001 Eclipse GS
42 psi is kind of alot.
This is from the 3G FAQ Quote:
"S" Car...Gooooooo
Vehicle: 03 GT-T
Over-inflated at that pressure? Absolutely. Additionally, the wear pattern looks a bit like the tire being dragged from a bad toe adjustment. What is the actual measurements on your alignment? Often times "in the green" isn't actually good enough. I blew through a set of Yokohamas in under 5000 km with an alignment "in the green". Get the printouts if possible. If you're dog tracking, combined with the higher pressure, that pattern may result imo.
Also, this also really ought to be in "problem reports" rather than here. Just saying. |
@Silvertune: The front tires have normal tire wear, a lot of people told me it could be bad rear struts but they don't have too much miles yet.
@fast gt:: Max tire pressure is 44 @SvenHoek:I will go and get the print outs, the last alignment check I got I remember the line being almost perfectly in the middle. I don't know what's the actual measurement, I'll try to get another alignment check and see what it is. I lowered the tire pressure, I have 34 in the front and 31 in the rear. I'm going to drive it around and see how it feels and I'm also going to try to get an alignment check soon and post it here. Thanks for all the help. |
#10 (permalink) | |
Just high tire pressure alone won't cause feathering, either bad struts or a toe issue or if you have worn parts allowing the tire to move when you're driving (bushings or bad toe links) that will cause feathering. The alignment can be all green with worn out shit, but as soon as the car comes off the rack it's all out of whack again.
#11 (permalink) | |
Redneck Yankee Mod..
Vehicle: 05 Eclipse Remix Edition
If life is a highway, mine is missing some signs. |
| Thread Tools | |
