How to adjust toe & camber? - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 08/30/2006, 04:32 PM   #1 (permalink)
I think too much
JoesInBoston's Avatar
JoesInBoston : who are you?JoesInBoston : who are you?JoesInBoston : who are you?JoesInBoston : who are you?
I am going to do my own alignment this weekend. I know how to measure everything, but I don't know how to adjust it. Does anyone have a picture of the correct components that need to be adjusted and which way to turn them for adjustment?
I can't believe someone hasn't made a DIY Alignment for the Garage yet.
JoesInBoston is offline   Reply With Quote Quick reply to this message
Old 08/30/2006, 06:17 PM   #2 (permalink)
I hate stance
XwP1ayawX's Avatar
Vehicle: V-ROD, R6, GST
Dude it's pretty cheap, just go have it done.
XwP1ayawX is offline   Reply With Quote Quick reply to this message
Old 08/30/2006, 07:54 PM   #3 (permalink)
bollocks
darklink's Avatar
Vehicle: 04 Z/00 3g
darklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by alldarklink seems to be well-liked by all
Send a message via AIM to darklink Send a message via MSN to darklink Send a message via Yahoo to darklink
Perhaps he wants the gratification of knowing how to do it himself. You could even score a little extra cash on the side for it.
There was a howto on alignment at some point, not sure where it went.
darklink is offline   Reply With Quote Quick reply to this message
Old 08/30/2006, 10:54 PM   #4 (permalink)
OMFG
NAPALM's Avatar
Vehicle: Cars
NAPALM should be considered a regularNAPALM should be considered a regularNAPALM should be considered a regularNAPALM should be considered a regularNAPALM should be considered a regularNAPALM should be considered a regularNAPALM should be considered a regularNAPALM should be considered a regularNAPALM should be considered a regularNAPALM should be considered a regularNAPALM should be considered a regular
Send a message via AIM to NAPALM
Your trusty Mitsu service manual will tell you what is factory adjustable, and where/how to adjust it.
Ill give you a brief summary fo what you are looking at for a full alignment.
-Camber is not adjustable in front nor back, from the factory. You need a set of coilovers with adjustable camber plates, or a camber kit to adjust front-end camber. Rear camber needs a camber kit as well, or you can make your own by installing some washers/spacers in between the upper control mounting flanges and the chassis.
-Toe is adjustable via the tie rod adjustments in the front and the manual shows you how on Page 33A-6.
-Toe is adjustable via the toe control arm in the rear. It is on an eccentric that allows adjustment of the toe.
Page 34-6 will show you how.
Good luck.
BTW; I made my own camber kit in the rear for my JICs and it worked great, dont waste your money on a camber kit.
Also, my rear didnt need any toe adjustment, so before you fool with that, set your desired camber, and then check your toe, if you didnt slam your car on the ground itll probably be ok.
NAPALM is offline   Reply With Quote Quick reply to this message
Old 08/31/2006, 07:17 AM   #5 (permalink)
I think too much
Actually, around here it is not cheap. I have only found a few garages that will align a lowered vehicle. It's upwords of 80-90 dollars for an alignment. If I can save 80-90 bucks, I'm gonna do it myself. And for the record, nothing is cheaper than free.
Good luck.
Thanks NAPALM. I found the thread on making your own camber kit and I am going to do that this weekend too.
Old 08/31/2006, 11:47 AM   #6 (permalink)
I think too much
NAPALM,
in 33A-8 it shows how to adjust the front camber by using different diameter strut bolts. Any idea where to get these different diameter bolts?
Old 08/31/2006, 12:47 PM   #7 (permalink)
Fossilized Member
rc_maniac's Avatar
Vehicle: '03 Spyder GuTS
Thumbs up
OEM Parts Online
Part numbers are:
MR333558
MR333559
MR333560
MR333561
Old 08/31/2006, 01:21 PM   #8 (permalink)
I think too much
E-Rep for you my friend
Old 08/31/2006, 03:12 PM   #9 (permalink)
Fossilized Member
rc_maniac's Avatar
thank you
Old 08/31/2006, 07:02 PM   #10 (permalink)
tracer bullet's Avatar
NAPALM,
Probably the eccentric / egg shaped bolts. It's hard to explain, but if you see them they make sense. You put one on each side through the bottom of the strut, and when you rotate it, the strut shifts around. Sort of. Hell I can't explain it even but again if you see them, they make sense.
You probably won't need them. I have the Tein springs, which are pretty low, and I'm on the edge of spec. Not sure what you have but... you'll probably be OK.
If you do have front camber issues though, PM me and I can sell you (for cheap) the ones I have. They are the standard kit you get at any store.
http://www.club3g.com/forum/showthread.php?t=64506
Old 09/01/2006, 07:25 AM   #11 (permalink)
I think too much
I don't really have camber issues in the front, I was just curious. I have Eibach Sportlines which are significantly low too.
