Honda pistons in 4g64 - Club3G Forum : Mitsubishi Eclipse 3G Forums
Go Back   Club3G Forum : Mitsubishi Eclipse 3G Forums > Performance & Tech Forums > 3G Eclipse RS/GS Specific
Old 03/19/2018, 03:43 PM   #1 (permalink)
Vehicle: 2000 eclipse gs
Ozzyr41n : who are you?
Was just curious if we are able to use oversized k20 pistons (86.5mm) in our block. I have a buddy who has a set of forged pistons that he is giving me. just wondering. planning on doing a turbo build soon, would be a good start.
Ozzyr41n is offline   Reply With Quote Quick reply to this message
Old 03/19/2018, 08:02 PM   #2 (permalink)
Stage 1 SDS @11+ psi
No
Old 03/20/2018, 11:06 AM   #3 (permalink)
why wouldn't it work though. the bore size would be the same and the wrist pin size is the same (22mm). the only thing I would be worried about is piston to deck height. any input? I just want an explanation as to why, not just a straight up "no".
Old 03/20/2018, 12:15 PM   #4 (permalink)
Really? You are asking me why "no"?
Come on, man.
Ok, I'll play. So what wrist pin you plan on using, Honda's or Mits? Then which rods? It's got to be Mits to fit to a Mits crank. Will the oil flow properly through the oil ports? And what about the valve reliefs? Will they match? etc etc etc There are so many variables to consider with what you are suggesting. Check into EVO parts.
Old 03/25/2018, 11:01 AM   #5 (permalink)
6G7X : who are you?
Is not worth it. I've done it with clients for N/A high compression engines. It's better to use H22 pistons. For boost just buy the right forged pistons
6G7X is offline   Reply With Quote Quick reply to this message
