Adjustable slave cylinder push rod - Club3G Forum : Mitsubishi Eclipse 3G Forums
Go Back   Club3G Forum : Mitsubishi Eclipse 3G Forums > Performance & Tech Forums > 3G Eclipse RS/GS Specific
Old 01/13/2019, 03:45 PM   #1 (permalink)
Donnie.man94 is similar to TE
I've pretty much given up trying to bleed the clutch Hydraulics.
New slave cylinder and new master cylinder is installed but after all the bleed the clutch is still to soft and moves the clutch fork only about a half inch, not even that? I also got a vaccum bleeder and still NOPE!
I popped the boot and seen the T.O.B get pushed against the pressure plate but no way is it enough to disengage the clutch as I can't shift into any gear with the car on.
So far I've received no help here so I'll try to get an adjustable push rod for the slave cylinder and if that doesn't work then I'll have to hire a mechanic I guess or just sell everything all together.
Would a longer push rod solve my problem?
Donnie.man94 is offline   Reply With Quote Quick reply to this message
Old 01/16/2019, 08:21 PM   #2 (permalink)
Btukwh : who are you?
Sounds like you haven't got it bled, yet.
It is difficult and takes a long, long time to bleed the clutch after you replace the slave/master.
Nothing else will work. Got to keep going.
Btukwh is offline   Reply With Quote Quick reply to this message
