Club3G Forum : Mitsubishi Eclipse 3G Forums
Club3G Forum : Mitsubishi Eclipse 3G Forums (https://www.club3g.com/forum/index.php)
-   Car Audio and Electronics (https://www.club3g.com/forum/forumdisplay.php?f=29)
-   -   2000-2006 Eclipse wiring diagrams (https://www.club3g.com/forum/showthread.php?t=55748)
MECP 02/02/2006 02:41 AM
PDF Files
2000 Eclipse
2001 Eclipse
2002 Eclipse
2003 Eclipse
2004 Eclipse
2005 Eclipse
2006 Eclipse
catalyst007 01/21/2007 10:32 PM
is there an updated list on these wiring diagrams??
thanks
MECP 01/21/2007 10:42 PM
Updated as in? DEI doesn't have any '07 diagrams out yet if that is what you are asking.
catalyst007 01/21/2007 10:47 PM
sorry my mistake, i saw that the 03 wasn't working, what i meant was is there an 03 up, or can i just relate to another year? (should be similair no?)
Nolanm_06 01/22/2007 01:16 AM
Originally Posted by MECP (Post 1482126)
Big help thanks!
Raiku 05/23/2007 02:56 PM
2003 link didnt work
MECP 05/23/2007 03:03 PM
2003 is fixed.
carlili4190 11/22/2007 08:25 PM
Ill start a new Thread for 2007
AgentSkully 02/23/2008 03:27 AM
thought these might be useful as well, if they are not appropriate then feel free to erase them. edit, this is the factory infinity wiring diagram for the 3g.
<a href="http://s151.photobucket.com/albums/s123/ldlemind/?action=view&current=2007-08-29_074722_4.gif" target="_blank"><img src="http://i151.photobucket.com/albums/s123/ldlemind/2007-08-29_074722_4.gif" border="0" alt="wiring diagram"></a>
<a href="http://s151.photobucket.com/albums/s123/ldlemind/?action=view&current=2007-08-29_074711_3.gif" target="_blank"><img src="http://i151.photobucket.com/albums/s123/ldlemind/2007-08-29_074711_3.gif" border="0" alt="wiring diagram"></a>
<a href="http://s151.photobucket.com/albums/s123/ldlemind/?action=view&current=2007-08-29_074643_1.gif" target="_blank"><img src="http://i151.photobucket.com/albums/s123/ldlemind/2007-08-29_074643_1.gif" border="0" alt="wiring diagram"></a>
mrbomb 03/08/2008 04:52 PM
where exactly is the ETACS ECU at? i think i located most of the wires in a plug that is on top of the fuse dash fuse box
also where is the 15 pin plug at? it says above the fuses but i cant really find it
this is for an 03 RS btw
if anyone could take some pics and point them out for me that would be awesome
quick92rs 06/05/2010 10:01 PM
DEI Directwire printout for a 2000.
http://i46.photobucket.com/albums/f1...ustoms/dw1.jpg
http://i46.photobucket.com/albums/f1...ustoms/dw2.jpg
http://i46.photobucket.com/albums/f1...ustoms/dw3.jpg
http://i46.photobucket.com/albums/f1...ustoms/dw4.jpg
May not be the same for all vehicles. I'll post up the different variations when I have more time.
abhoover29 05/06/2011 12:14 AM
Does anyone have a wiring diagram for 2000 eclipse gt? The links at the top are not working and I have searched for anything without luck.
MECP 05/06/2011 12:26 AM
In the above links, replace www.raminal.com with family.raminal.com. I'll update the web server tomorrow to fix the links.
JermTheElf 07/16/2011 08:50 AM
Couldn't get the links to work, I found a wiring diagram for the 2000-2002 eclipse. This is just for alarm installs which is what I needed them for.
2000 -2002MitsubishiEclipseVehicle Wiring Chart and Diagram
bpears 01/17/2012 09:11 PM
Yeah, that's not working either. :dunno:
MECP 01/17/2012 09:26 PM
Links in the top post work fine for me...
bpears 01/20/2012 11:36 PM
2001 is the only one I think isn't working... n that's the one I want! :(
Daquan803 12/31/2012 03:50 PM
I need 2001 !
Daquan803 12/31/2012 03:52 PM
Do anyone have the radio wire diagram ?
MECP 12/31/2012 04:18 PM
There's a lot more to the radio than just wiring depending if you have premium sound or not. Either way, you should use an adapter and not cut the factory harness.
Ken 01/01/2013 04:39 PM
The pinout information can be found in the FSM. Search and you shall find it.
kristi3193 10/10/2013 10:27 PM
I have a question about cruise control. I have a 2003 eclipse. It's my baby :) but my cruise control went out. And I'm wondering what happened. The light comes on on the dash. But the cruise control itself isn't working. Could it be a fuse? Or what?
Brandon1310 01/22/2014 11:04 PM
Fuel injector wires ripped
I ripped the fuel injector wires from injectors 1,3, and 5. I ripped them out of a 4-prong harness which when all plugged on right lead from the fuel injectors to the distributor. Now I don't know which wire goes to which prong on the connector. Can anyone help?!
gabessdsp 01/28/2014 10:10 AM
Try posting in the new members forum or an engine forum. This thread is about wiring diagrams.....:scratch:
remotefailure 07/24/2016 09:21 PM
Is the infinity amp a six channel amp?
I'm at the cross roads of wanting to upgrade my infinity system on my 2000 gt, and so I'm wondering what to do first. Should i get a replacement for my infinity amp, and upgrade the speakers, or first go with a replacement head unit, most of which only have 4 channels of amplification. I've read that the amplifier was 2 ohm, so I'm guessing that most after market radio's will not work well with this ohm rating.
If the factory amp is indeed, a six channel system is it possible to wire up the the system so that tweeters, center channel, and door speakers are the front channel, and then say the rear speakers are for the rear?
Or maybe do something like have the tweeter/ center channel as the front, door speakers, as rear channel from the head unit amplifier, then use a sub out to a 2 channel amp for the rear seat wall speakers.
When i look at speakers all the 6x9 speakers always have way more power handling capability then, the 6.5" speakers in the doors, which from my perspective making it difficult to find a amp that would match well, since most all seem to have equal rms ratings a crossed all channels.
What does every one else do? Do you ditch the tweeter/ center channels when using a 4 channel head unit with built in amplifier?
johnny340 12/28/2016 12:38 PM
I just put in one of these and kept the existing amp and speakers.
https://www.pioneerelectronics.com/P...ers/MVH-X580BS
I cannot believe the improvement! I did this swap mainly for blue tooth etc but the sound is so much better!!! This amp is super cheap, sounds great and has amazing features. Second vehicle I've put one in and highly recommend them.
Get the premium stereo wiring harness adapter kit which comes with the two RCA pairs and main connector (you only use 3 of the 4 factory wires) and don't worry about the other small connector on the factory stereo since the speakers are hooked up to the amp already. Plus you need a single din surround obviously and that's it! $130 total and you will be very happy.
By the way, the links above don't work (as mentioned) but you don't really need this info if you use an adapter harness.
soundman98 12/28/2016 06:35 PM
the sound quality can't change if you only did the deck. the stock speakers and stock amp would cripple a new deck to the same level as what the oem radio did.
i suspect the loudness is turned on, which artificially boosts the low's and high's, or your eq settings are skewing your perception.
johnny340 12/30/2016 05:05 PM
Power, Speakers, Signal. You need all three for a good system. The signal from this 13 year newer deck is much better and sounds way way better. I don't think the improved sound has anything to do with EQ or loudness settings but even if it does, who cares, this now sounds great for a small outlay of cash for those on the fence deciding what to do.
soundman98 12/31/2016 12:48 PM
it's false advertising to others to indicate that a simple deck change can change the overall sound, because it simply can't. the oem deck and aftermarket decks both offer similar 2v preamps, so there's no loudness difference there, and the overall sound quality of the system components is the same, so there can't be any difference there either. the only difference there can be is the sound-shaping options in the new deck, and pioneer likes to enable those by default in an effort to 'wow' people that install the deck to think that it was that dramatic of an improvement, which is what i believe is affecting your opinion-- just as new tv's have a 'home' setting and a 'store' setting which changes the color tints to look better on the store shelves.
in my eclipse history, i've run 2 different pioneer decks with the stock amp(have had 6 different pioneer decks total), as well as a full aftermarket amplified system, and a full-active carpc setup. the only thing i never did in the eclipse was a 5.1 setup because the speaker locations didn't allow for good placement, but the center dash speaker which allowed for a 5.1 setup was a main motivator for buying the car..
johnny340 01/09/2017 08:46 PM
My ears don't lie. The deck changed and the sound got better; maybe due to features not available on the stock deck but who cares? It's better. End of story. It's false advertising to suggest this isn't possible. Not everyone needs to spend $2000 on the system in their $2000 car like you did.
Just trying to help.
Go ahead and get that last post in....I won't be checking.
All done here.
