13.869 @ 103.91 - Club3G Forum : Mitsubishi Eclipse 3G Forums
Go Back   Club3G Forum : Mitsubishi Eclipse 3G Forums > Driving & Driving Tech Forums > Drag Racing Tech
Old 05/22/2015, 09:37 PM   #1 (permalink)
Stage 1 SDS @11+ psi
13.869 @ 103.91
When to the track tonight. The car performed well. The driver did not. Horrid 60' times. Headwind of 8 mph.
Click image for larger version
Old 05/22/2015, 09:56 PM   #2 (permalink)
Vehicle: Eclipse
RxTec : who are you?RxTec : who are you?
Good work
RxTec is offline   Reply With Quote Quick reply to this message
Old 05/23/2015, 12:07 AM   #3 (permalink)
Boost 44203's Avatar
Vehicle: 03 Eclipse GS-T
Boost 44203 : who are you?Boost 44203 : who are you?Boost 44203 : who are you?Boost 44203 : who are you?Boost 44203 : who are you?
That's moving. V6 I assume?
Boost 44203 is offline   Reply With Quote Quick reply to this message
Old 05/23/2015, 01:48 AM   #4 (permalink)
Yup
Old 05/23/2015, 02:17 PM   #5 (permalink)
I really think I can improve on that time. Just need more practice.
Old 05/24/2015, 10:32 PM   #6 (permalink)
Lift and Separate
Voodoo's Avatar
Vehicle: 03 Ultra Red GS-T
Voodoo seems to be well-liked by allVoodoo seems to be well-liked by allVoodoo seems to be well-liked by allVoodoo seems to be well-liked by allVoodoo seems to be well-liked by allVoodoo seems to be well-liked by allVoodoo seems to be well-liked by allVoodoo seems to be well-liked by allVoodoo seems to be well-liked by allVoodoo seems to be well-liked by allVoodoo seems to be well-liked by all
Nice times If you can perfect that launch you'll be mid 13s easily
-Rob
PM me for Evo 8 parts
Voodoo is offline   Reply With Quote Quick reply to this message
Old 05/24/2015, 10:54 PM   #7 (permalink)
Thanks.... I think I'm also a little tentative because of dealing with the experience of bent valves due to a shredded SDS belt after a 1/4 run.
Old 05/26/2015, 07:27 AM   #8 (permalink)
Engineer/Realist
malachi's Avatar
Vehicle: 2000 RS
malachi seems to be well-liked by allmalachi seems to be well-liked by allmalachi seems to be well-liked by allmalachi seems to be well-liked by allmalachi seems to be well-liked by allmalachi seems to be well-liked by allmalachi seems to be well-liked by allmalachi seems to be well-liked by allmalachi seems to be well-liked by allmalachi seems to be well-liked by allmalachi seems to be well-liked by all
nice man, drop that 60' and with a 103 MPH you will be knocking on 12's door!
stock RS 16.1 in 1/4 mile
car on diet, but still stock = 15.58
2006 FASTEST ECLIPSE RS/GS STOCK
2006 FASTEST ECLIPSE RS/GS N/A
2008 NEW RECORD, RS/GS N/A = 15.2
2009 DOHC + 10psi = 14.0 @ 101.89MPH
2009 DOHC + 15psi = 13.3 @ 108MPH
2010 DOHC + ~psi = [email protected] 102MPH
FOR SALE - PM ME
2000RS-Turbo is my cock sucking bitch! NEG HIM!
BLACK OPS
10-0 "one in the chamber" - FLAWLESS
malachi is offline   Reply With Quote Quick reply to this message
Old 05/26/2015, 09:45 AM   #9 (permalink)
V8 > 3G
skinnyGT's Avatar
Vehicle: racecar
skinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by allskinnyGT seems to be well-liked by all
Send a message via AIM to skinnyGT
Were you spinning through 3rd? You gained 30mph on the big end so you should be in the 12s if you can put the power down.
skinnyGT is offline   Reply With Quote Quick reply to this message
Old 05/26/2015, 12:46 PM   #10 (permalink)
Yeah, a good 1/4 is all about traction. I did lower my front tires psi to 30 lbs.... it wasn't enough (I usually drive around at 35 lbs. in the front tires). I was spinning all the way through third. Maybe the next time I'll get them down to 25-26 lbs...
I know where I could borrow some EVO slicks... But I'm not likely willing to put my drive train through that kind of punishment.
Old 05/27/2015, 07:19 AM   #11 (permalink)
Engineer/Realist
malachi's Avatar
Vehicle: 2000 RS
do you have a stock Dif?
a limited slip will change the world, ask voodoo. or you could go my route and have more problems than you want, and just weld it and make a solid diff! lol
FOR SALE - PM ME
BLACK OPS
Old 05/27/2015, 08:08 AM   #12 (permalink)
I have a Quaife already. lol
Old 03/14/2019, 04:52 AM   #13 (permalink)
marthawilliam : who are you?
thanks for this
marthawilliam is offline   Reply With Quote Quick reply to this message
« 10.682 @ 138.23 | - »
