Well, She's (SDS) in... - Page 18 - Club3G Forum : Mitsubishi Eclipse 3G Forums
Go Back   Club3G Forum : Mitsubishi Eclipse 3G Forums > Performance & Tech Forums > Forced Induction & Nitrous > GT/GTS
Old 09/14/2017, 06:52 AM   #1021 (permalink)
Vehicle: 2000 eclipse
Rectzero : who are you?Rectzero : who are you?Rectzero : who are you?
We should meet up sometime. You live so close.
Rectzero is offline   Reply With Quote Quick reply to this message
Old 09/16/2017, 10:30 PM   #1022 (permalink)
Stage 1 SDS @11+ psi
Yeah, that would be cool. Alas, time is the issues these days. I literally have none most of the time. :/
Old 07/17/2018, 10:50 PM   #1023 (permalink)
So I had a trouble shooting adventure recently. My BOV failed... not overly surprising since it was a Greddy Type S knock-off from ebay. Lasted as long as the car has been boosted. But when the BOV failed, it took the ISC Motor with it. Little bit of a pain to find because no codes were thrown and vacuum levels were good. Dealership wanted $505 for new ISC motor. I found one for much less. After repairing both, the car runs as it always has.
Old 07/18/2018, 07:17 PM   #1024 (permalink)
How are those two even related? It mechanically damaged it by jamming a bunch of boost up against it?
Old 07/18/2018, 07:50 PM   #1025 (permalink)
I guess. There was a lot of play with the plunger. It kind of makes sense. I'm not running such high boost that compressor surge would be an issue. But the pressure has to go somewhere and the ISC ports in the throttle body seemed the likely escape route. Believe me, that was one of the last places I looked.
Once I replaced the failed BOV, I set the new one to the softest settings, essentially allowing any of the compressed air from the blower to get diverted. But the idle was just all over the place. After spending a lot of time entertaining the more likely fail points, I pulled the ISC motor and determined it was damaged. Once the new one when in, all of my idle issues were gone... after tightening up the BOV spring and verifing ISC steps were where I had them programmed.
Old 07/18/2018, 08:18 PM   #1026 (permalink)
That's a weird one for sure, I guess the plunger being forced back and forth could create some feedback via inductance but that would more likely damage the driver circuit than the ISC motor itself. The Mitsu V6 ISC's are always touchy anyway, always have been.
Old 09/06/2018, 02:31 PM   #1027 (permalink)
Nothing really new to report other than I finally got around to putting the Seibon hood on. My other carbon fiber hood was just cracking all to hell.
Sent from my iPhone using Tapatalk
Old 01/16/2019, 05:42 PM   #1028 (permalink)
So I have some real news!
This:
I’ve had this motor for a while. Got it from Greg when he moved to Texas and had to get rid of excess inventory. It has 8.8:1 CP pistons, Pauter rods with ARP fasteners, bored 20 over and had the crank rebalanced. It was pulled from a SDS car and sat in my garage for about a year and a half.
Wasn’t totally sure of its condition so I opted to have the block refreshed at a machine shop: new bearings and rings, crank polished, new freeze plugs, honed the cylinder bores, and had it decked.
Old 01/16/2019, 05:49 PM   #1029 (permalink)
Slapped a new Clutchmasters FX 350 clutch in there with a new flywheel insert.
Old 01/16/2019, 05:54 PM   #1030 (permalink)
Attached the trans and put the whole assembly back in the car from underneath.
Heads and most of the upper assembly back on back on:
And done! With a newish V-3 Vortech Ripp SDS.
Old 01/19/2019, 03:11 PM   #1031 (permalink)
Also added a Damond venting oil catch can. My previous catch can did not vent causing some back-pressure oil leaks.
Old 01/19/2019, 09:51 PM   #1032 (permalink)
REDLINE ALL GEARS
thahnic1080's Avatar
Vehicle: 2002 GT-T
wait did that motor come from the silver rippmods stratus. Looks good what do you plan on doing with the other blower set up
sponsored by Braille Battery, Mishimoto, Ramey built, Superior Autotech
thahnic1080 is offline   Reply With Quote Quick reply to this message
Old 01/19/2019, 11:11 PM   #1033 (permalink)
I don't think so but maybe. (Actually, I kinda said that in one of the above posts... I meant to say it came out of a SDS car but wasn't necessary THE Ripp Status). I know the Ripp car was at Greg's for a bit.
Old 01/19/2019, 11:19 PM   #1034 (permalink)
At this time, I plan on keeping my spare SDS stuff. With the built engine, upgrade options have opened up. We'll see where the power level ends up with the V-3.
Old 02/20/2019, 12:07 AM   #1035 (permalink)
So I started experiencing some weird idle issues.... the idle was hunting with big RPM swings. And while running in boost, acceleration seemed very soft. Everything pointed toward a massive vacuum leak. I was a little concerned because it could be something simple or something more catastrophic like the valve train or such.
Thankfully, it turned out to be something really simple: The screw holding in that spring loaded diaphragm at the bottom of the TB vibrated loose. Tighten it back up with some Loctite and done! I was glad that I just had to pull the intake plenum off. Slapped everything back together and no more run issues.
Hoping in the coming weeks I can do a little more street tuning. The current SDS tune is still set for the Vortech V-5 and original GTS pistons. I should see a fairly significant improvement based on some of the boost numbers Iíve already seen from the V-3. Timing and fuel all need to be adjusted. I also plan to get her back on the dyno when summer temperatures arrive.
Old 04/04/2019, 03:13 PM   #1036 (permalink)
Vehicle: 2001 GT
buddd : who are you?buddd : who are you?
That short block looks like it came from the factory. Probably better.
Also, it's amazing how you managed to keep your engine bay looking that nice after all of this time.
Looking forward to dyno plots.
buddd is offline   Reply With Quote Quick reply to this message
Old 04/05/2019, 01:36 PM   #1037 (permalink)
For the first three years of the carís life, it was a garage kept daily. But when I got serious about modding it, I bought a second car. For the past 14 years, itís been protected by the garage and never sees the rain. So it looks brand new, inside and out.
Been doing a little tuning and hope to see the dyno some time this year. Not expecting a profound jump in HP numbers, but there definitely should be some across the board improvement.
And yeah, the machine shop I went to did a great job.
Old 04/10/2019, 08:09 PM   #1038 (permalink)
Mattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by manyMattt is well-liked by many
Originally Posted by Mattt View Post
Id like to see this thing sometime, I live just west of Baltimore.
Mattt is offline   Reply With Quote Quick reply to this message
Old 04/15/2019, 02:23 AM   #1039 (permalink)
Some of my initial observation with my current set up is that the V-3 is producing around 2 psi more at each respective rpm level than the V-5 did. Peak boost hasn’t gone beyond 12 psi and that’s because I’m getting some belt slippage. Need to tighten it up a bit more.
I’ve got a little bit of work to do on the tune. The water/methanol start and peak points still require more refining. As I adjust the fuel to match the bigger blower, I‘m able to pull the timing a bit. I honestly can’t tell if I’m making profoundly more power. She’s getting it really good right now. Tuning is the fun part!
I am seriously thinking about putting the stock cat-back on, but also adding a cut-out before it. The car is way too loud in its current form and it sticks out way too much. Future project.
Old 04/15/2019, 10:27 PM   #1040 (permalink)
There's a good chance I'll be at the Import Shootout @ Capitol Raceway June 2nd.... weather and family functions permitting.
Old 04/16/2019, 08:21 PM   #1041 (permalink)
REDLINE ALL GEARS
Vehicle: 2002 GT-T
ill probably be there with friends
« Supercharging | - »
