Possibly overheating? Or ifk - Club3G Forum : Mitsubishi Eclipse 3G Forums
Go Back   Club3G Forum : Mitsubishi Eclipse 3G Forums > Welcome Forums > New Members Forum
Old 04/21/2019, 03:19 PM   #1 (permalink)
Asharoo's Avatar
Asharoo : who are you?
Idk if anyone else has a issue with slight over heating at idle. 149,930 miles. New water pump, alternator, battery, mishimoto radiator, new ac compressor and serpentine belt too. I dont know if it's just the reading or what ALSO HOW DO I POST A PHOTO ON HERE?
Asharoo is offline   Reply With Quote Quick reply to this message
Old 04/24/2019, 04:39 PM   #2 (permalink)
Vehicle: 2005 330XI
buddd : who are you?buddd : who are you?buddd : who are you?
You didn't mention a new thermostat. If you are overheating, I'd replace that. It's a cheap part and easy to access. Then make sure you burp the coolant system to make sure there are no air bubbles.
buddd is offline   Reply With Quote Quick reply to this message
Old 04/24/2019, 06:47 PM   #3 (permalink)
nickthorne33 : who are you?
If it's only overheating at idle, my experience has been that it's usually the radiator fan. Because when your driving, it will have air running through the fan anyways. What I'd do, is turn on the A/C, and idle the car until it gets up to temp. At that point, both fans should be on. If one fan kicks on, but not the other, then you'll know your problem. But a thermostat is not a bad idea either, since you're that deep into the cooling system already
nickthorne33 is offline   Reply With Quote Quick reply to this message
Old 04/24/2019, 09:51 PM   #4 (permalink)
Vehicle: 2003 Eclipse GTS
Kyzaon : who are you?Kyzaon : who are you?
If your fans work properly, your radiator could be clogged, if you can't afford a new one or you just don't want to buy one, you can always take it off and clean it. There are videos on YouTube on cleaning blockages.
Kyzaon is offline   Reply With Quote Quick reply to this message
Old 04/26/2019, 01:06 PM   #5 (permalink)
Asharoo's Avatar
Yes. The thermostat has been changed recently as well and no the mishimoto radiator is also new so it cant be clogged. Both fans kick on actually.
Old 04/26/2019, 02:37 PM   #6 (permalink)
Was the coolant system burped properly? If you have air bubbles your system wouldn't be working at peak performance, causing the engine to heat at idle.
Old 04/30/2019, 11:34 PM   #7 (permalink)
Asharoo's Avatar
I believe so ... I could redo but if not then what???
Old 05/01/2019, 11:36 PM   #8 (permalink)
rasheid : who are you?
What could happen is the fins on the water pump has disintegrated and requires higher engine speeds to move the water.
rasheid is offline   Reply With Quote Quick reply to this message
Old 05/02/2019, 02:58 PM   #9 (permalink)
Vehicle: 2005 330XI
If your fans and thermostat are working, I bet you it needs to be burped. It's a pain in the ass with these cars. Works better if you can park on a hill with the nose facing up. Engine needs to be warm to make sure coolant is flowing through the whole system. I found a funnel that I could jam in the fill neck of the radiator and filled the funnel half way. Then with the engine running I'd rev the engine gently and watch the fluid in the funnel rise. Release throttle and repeat. When bubbles stop coming out, the system is burped.
Also, just because the radiator is new, doesn't mean it can't be clogged. Depends on how nasty the system was before you changed it. If it was bad, something may have migrated from the block to the new radiator. Also, manufacturing defects happen.
Finally, make sure your coolant hoses aren't kinked. Not sure which ones you used, but if they are universal style ones, they may be kinked where they are bent.
Old 07/19/2019, 08:10 PM   #10 (permalink)
Asharoo's Avatar
I appreciate the Insight. BUT ITS STILL OVER HEATING AT IDLE. I burped the system like yall said but I have no idea would it could possibly be!!!!!! Ima go crazy. Everything involving the cooling system has been NEWLY changed within the past year......
Timing belt/waterpump
Mishimoto radiator
Thermostat
The entire AC Compressor and everything that involves that
(Serpentine belt too)
I have no idea what it could be..... if I idle in 1st gear with the AC blowing cold oN full blast, IT USED TO BE FINE. TILL IT STARTED GETTING SLIGHTLY HOTTER EVEN WITH AC BLOWING COLD. BUT IF I put it on Hot it'll go back down. I dont need this B.S please help???? Could it be a blown head gasket???????? That's the only thing I could thing of. I hope not and I dont see any symptoms of that. I DONT KNOW?! help!!!!
Old 07/19/2019, 08:12 PM   #11 (permalink)
Asharoo's Avatar
Possibly overheating? Or idk
Sitting at 151,000k if that helps..
Old 07/21/2019, 01:56 AM   #12 (permalink)
Donnie.man94 is similar to TE
are you losing coolant? did you get a new radiator cap?
Donnie.man94 is offline   Reply With Quote Quick reply to this message
Old 07/21/2019, 12:46 PM   #13 (permalink)
Asharoo's Avatar
No coolant lost from what I've seen. And well the whole radiator was new.?Including cap and all
Old 07/22/2019, 11:03 AM   #14 (permalink)
Vehicle: 2005 330XI
Do some troubleshooting, man. Check to see if you radiator is clogged by using a laser thermometer or thermocouple in different sections. Check for coolant flow in the hoses by squeezing them off and slowly releasing them. Check to make sure you didn't get faulty thermostat by checking its operation. Check to make sure your fans are cycling properly. I believe they have both a high speed and a low speed. Make sure they both work.
Just because you have new parts doesn't mean they aren't messed up. Manufacturing mistakes happen. Cooling systems on these things aren't complicated. You can do this if you just take some time and verify that things are working the way they should. It'll certainly get you further than coming in here and typing up a frantic post because you are just replacing things without doing a thorough diagnosis.
Old 07/23/2019, 04:57 PM   #15 (permalink)
Does your radiator have a hose from the top of the radiator going to the coolant reservoir?
Be sure you aren't losing coolant
fill your radiator all the way to the top
fill your coolant Reservoir all the way to FULL
get your car temp up and watch for bubbles in the coolant reservoir.
If you have a leak anywhere in the system, air will stop the flow of coolant in the system.
When air is in the system, air goes to the top(highest point) . The radiator cap is supposed to open up at 16 psi to release trapped air(bubbles) into the coolant reservoir and coolant will go back up the tube replacing the trapped air with coolant.
I also had to drive after the first burping of coolant to %100 get the trapped air out.
Check the coolant level after the car is cooled down all the way. (if hoses are warm then you still have to wait longer)
I seriously just solved my coolant loss issues after a long time so I'll help you with everything I did
Old 07/31/2019, 10:34 PM   #16 (permalink)
happydemon : who are you?
Didn't see if you checked the fans without A/C or defrost on, I had a corrupt ECU that cycled the fans for A/C and defrost, but fans wouldn't turn on from the temp sender. I should also mention the temp sender for the fans is different than for the cluster, so it could prevent them coming on from temp also.
happydemon is offline   Reply With Quote Quick reply to this message
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
2003 gs 2.4 m/t overheating issues fixed!!!! Eblove911 Problem Reports 0 12/08/2017 08:28 PM
Overheating and blowing hot air (No A/C) Sandlotje Problem Reports 0 05/08/2013 06:44 PM
my 96 eclipse is overheating 96eclipse Problem Reports 1 04/11/2013 08:55 AM
Engine Overheating After TB coolant line Bypass 00 Problem Reports 10 02/10/2012 10:09 AM
2001 GT Overheating While Stopped dt2001gt Problem Reports 4 11/23/2011 04:24 PM
