weird idle issue - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 01/20/2019, 05:17 PM   #1 (permalink)
Jnspayne : who are you?
weird idle issue
2003 Eclipse GTS: Just went over 300k
The car is idling at around 1400rpms and fluctuating to 1500rms intermittently. Sometimes it stops when the car in in neutral and the clutch disengaged. Most of the time it happens when the clutch is engaged. If you release the clutch just to the point of friction, it goes away, but still idles too high.
I have replaced the IAC, cleaned the throttle body and ERG and replaced the EGR solenoid. I did fiddle with the idle screw when I cleaned the throttle body. Probably should not have touched it. The screw is almost in all the way at 1400 rpms idle.
I will probably replace all the vac hoses next, just in case. Would a throttle body from a junk yard be the way to go. Maybe the TB hasn't been messed with. TPS?
Looking for ideas.
Jnspayne is offline   Reply With Quote Quick reply to this message
Old 01/21/2019, 12:22 AM   #2 (permalink)
Stage 1 SDS @11+ psi
Did you take the TPS out? You need to put that in the right position. You'll need a login program to see if you had 0% when the throttles close and 100% when it's wide-open.
Old 01/21/2019, 12:57 AM   #3 (permalink)
Yes. I took the TPS off. Not my best moment. Should have researched first. Do I need to take it to the dealer or is this something I can do myself
Old 01/21/2019, 08:48 PM   #4 (permalink)
The tps needs to be clocked properly. Get a logging program (EVO Scan is great but you have to get a Tactrix 1.3 or 2.0 cable/adapter) so you can confirm 0% and 100%.
Old 01/22/2019, 11:19 PM   #5 (permalink)
Thanks. It looks like the 1.3’s are getting hard to find.
