Shifts into gear hard sometimes? - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 02/22/2019, 01:00 AM   #1 (permalink)
kilsnacks's Avatar
kilsnacks : who are you?
I've got a 2002 rs and my shifter doesn't go back to center by itself if I move it left or right and when I put it into gears it sometimes is hard going into the gear I replaced the fluid with Amsoil fluid last year sometime as well. It seems to be better when I drive it for a while or if it's warm out but it will still go into gear a little hard sometimes regardless. Could the problem be the cable bushings? I've lubed the cables a few times which helps somewhat for a month or 2. I also replaced the master and slave cylinders with direct parts from Mitsubishi
kilsnacks is offline   Reply With Quote Quick reply to this message
Old 02/23/2019, 06:04 PM   #2 (permalink)
Donnie.man94 is similar to TE
check out this post , 6th picture down is the return spring which places the shifter back into the middle when you are out of gear.
if you check out the second picture down, that is your shift control housing. see the only rusted circle in the picture? you should be able to push that in if the car is in neutral and it should return to its orignal position when not pressed.
also try making sure all bolts holding the shifter assembly in the trans is secure and make sure your shifter bushings arent oval shaped.
hope this helps
i would assume if that doesnt happen then its a start to finding your issue, hope this helps
https://www.club3g.com/forum/perform...-included.html
Donnie.man94 is offline   Reply With Quote Quick reply to this message
Similar Threads
Thread Thread Starter Forum Replies Last Post
CARS IN GEAR BUT WONT MOVE.. HELP! THATBLUE3G Problem Reports 2 05/21/2015 10:03 PM
Hard disk data recovery. primula Gaming and IT Discussion 7 04/17/2015 08:01 AM
locked out of 1st gear bobbyloco8 Problem Reports 2 04/26/2011 05:30 PM
Car Won't Go In Gear! Dread_The_Red Problem Reports 5 04/24/2011 02:41 PM
need a new hard drive. asking opinons. chavezeclipse Gaming and IT Discussion 11 02/13/2010 05:11 PM
