High/rough idle please help! - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 03/26/2019, 09:42 PM   #1 (permalink)
debronzo : who are you?
I have a 2001 rs 2.4l, I’ve replaced just about everything on this car.. a brand new motor with 0 miles, all new motor mounts, new intake system, new headers, a new exhaust, new plugs and wires, I just ordered a new egr valve praying it’ll fix my issue, but even before I replaced the engine the damn thing has a rough idle and at time it will idle at around 2k! I sprayed with carb cleaner and couldn’t find any vacuum leaks, if anyone has found the problem for this please let me know!
debronzo is offline   Reply With Quote Quick reply to this message
Old 03/27/2019, 05:37 AM   #2 (permalink)
Redneck Yankee Admin
Chad's Avatar
Vehicle: 05 GS-T Remix Edition
Chad is God.Chad is God.Chad is God.Chad is God.Chad is God.Chad is God.Chad is God.Chad is God.Chad is God.Chad is God.Chad is God.
1 thread only in the future, we don't need 4 of the same threads spammed across the site.
Chad is offline   Reply With Quote Quick reply to this message
Old 03/27/2019, 05:12 PM   #3 (permalink)
Stage 1 SDS @11+ psi
Originally Posted by debronzo View Post
I have a 2001 rs 2.4l, Iíve replaced just about everything on this car.. a brand new motor with 0 miles, all new motor mounts, new intake system, new headers, a new exhaust, new plugs and wires, I just ordered a new egr valve praying itíll fix my issue, but even before I replaced the engine the damn thing has a rough idle and at time it will idle at around 2k! I sprayed with carb cleaner and couldnít find any vacuum leaks, if anyone has found the problem for this please let me know!
What data-logging a have you done? If you don't know what your LTFTs, Throttle position, ISC steps, and target idle speed you are wasting your time.
You have to use that information to then adjust the idle screw properly. Or just see where the screw is set at. Might have a vacuum leak.
Old 03/27/2019, 08:07 PM   #4 (permalink)
Do you know where I can find the correct data for when I log that data?
Old 03/28/2019, 10:03 PM   #5 (permalink)
Bump
Old 03/29/2019, 11:56 PM   #6 (permalink)
There are datalog programs online that use the OBD2 port. I use EVOScan, but the are other programs out there.
Old 03/31/2019, 08:58 AM   #7 (permalink)
Yeah I found some oem data on identifix, I just installed my egr valve yesterday and I’m gonna compare the readings I got on my snap on scanner with what’s on there
Similar Threads
Thread Thread Starter Forum Replies Last Post
EvoScan v2.6 results. High idle, low idle, surging idle. Please help New2Mitsu Problem Reports 2 02/20/2013 08:22 AM
HOW TO: testing IAC (idle air control) countryrunner Maintenance 0 10/09/2010 06:09 PM
Did a spark plug swap now I have an extra sensor and a high/rough idle. EclpseGT3G Problem Reports 8 05/06/2010 11:58 AM
