Wheel and Tire Sizing and Fitment Guide - Page 3 - Club3G Forum : Mitsubishi Eclipse 3G Forums
Old 09/03/2009, 07:39 PM   #121 (permalink)
spammusubi36 is similar to TE
will this fit
i was wondering if 245/40/19 tires would fit on my eclipse
the suspension is stock
also if this would look stupid without a drop
spammusubi36 is offline   Reply With Quote Quick reply to this message
Old 09/04/2009, 08:36 PM   #122 (permalink)
bad mojo's Avatar
Vehicle: 2001 eclipse RS
bad mojo seems to be okaybad mojo seems to be okaybad mojo seems to be okaybad mojo seems to be okaybad mojo seems to be okaybad mojo seems to be okay
245/40/19 is too tall.
go with a 245/35.
the enemy of excellence is satisfaction.
bad mojo is offline   Reply With Quote Quick reply to this message
Old 09/19/2009, 02:17 AM   #123 (permalink)
timster2833's Avatar
Vehicle: '03 Eclipse GTS
timster2833 should be considered a regulartimster2833 should be considered a regulartimster2833 should be considered a regulartimster2833 should be considered a regulartimster2833 should be considered a regulartimster2833 should be considered a regulartimster2833 should be considered a regulartimster2833 should be considered a regulartimster2833 should be considered a regulartimster2833 should be considered a regulartimster2833 should be considered a regular
What do you guys think about 18x9" +35 offset Rota G-force Rims with 255/35R18 mounted on them? Currently I'm running these rims with 225/40R18 with 1/4" spacers for a little extra clearance (I have evo brembo calipers mounted right now) I don;t care about the tires sticking out because I'm getting Shine fender flares to take care of that... I used the tire size website posted above to compare the 2 tire sizes and the 255/35 is 1mm shorter than the 225/40... but my question is with 1/4" spacers all around and the +35 offset do you think the 255 width is going to rub or is there anyone out there running a similar setup? Thanks for the help guys! -Tim
timster2833 is offline   Reply With Quote Quick reply to this message
Old 09/19/2009, 06:00 PM   #124 (permalink)
bad mojo's Avatar
255/35 will sit square on the 18x9.
you won't have any problems...you also don't need spacers.
Old 11/25/2009, 08:12 AM   #125 (permalink)
Tracy, NorCAl
Vehicle: 01 Spyder GT
Green_Spyder : who are you?
Originally Posted by SUPER MANNY View Post
hey will 18" rims fit on stock suspension with out rubbing +40 offset and 7.5
I am running Enkei 18x8 40 offset 235/40/18 tires With Skunk2 springs (2"inch drop). I have no rubbing & turning issue. The Fitment is good.
Green_Spyder is offline   Reply With Quote Quick reply to this message
Old 11/25/2009, 07:56 PM   #126 (permalink)
Iconzx6r's Avatar
Vehicle: 04 GTS
Iconzx6r : who are you?
Hey guys, need a little insight for offset. I'm in love with these wheels for my 04 gts but I can't tell how they will sit with the offset.
18x8.5 Rota Torque - Yamaha Black(5x100/e45/73) Wheeldude.com - Professional wheel dealer. #1 Rota Dealer.
I'd like them to sit as flush with the edge of the fenders as possible (but not protruding) and I'm getting Eibach Pro kit.
Will they fit? Thanks dudes.
Iconzx6r is offline   Reply With Quote Quick reply to this message
Old 11/25/2009, 08:12 PM   #127 (permalink)
aaronsspyder's Avatar
Tetris Champion! Hexxagon Champion!
Vehicle: 10 Jaguar XF-R
aaronsspyder is well-liked by manyaaronsspyder is well-liked by manyaaronsspyder is well-liked by manyaaronsspyder is well-liked by manyaaronsspyder is well-liked by manyaaronsspyder is well-liked by manyaaronsspyder is well-liked by manyaaronsspyder is well-liked by manyaaronsspyder is well-liked by manyaaronsspyder is well-liked by manyaaronsspyder is well-liked by many
I'm pretty sure 8.5" is pushing it. I remember hearing that the widest to go without protruding is 8".
aaronsspyder is offline   Reply With Quote Quick reply to this message
Old 11/25/2009, 08:19 PM   #128 (permalink)
Iconzx6r's Avatar
Vehicle: 04 GTS
I was hoping the 45 offset would tuck it under enough. I prefer 18x8 but the site doesn't list that size in 18". They have a billion sizes but I'll check around other places for them.
Edit: stroke of genius, bolt up my Evo X BBS rims, they are almost exactly the same size. 1 mil differnce in offset is all!
Old 11/25/2009, 09:37 PM   #129 (permalink)
02gt's Avatar
Vehicle: 6g74 3.5L 02gt
02gt has a few friends here02gt has a few friends here02gt has a few friends here02gt has a few friends here02gt has a few friends here02gt has a few friends here02gt has a few friends here02gt has a few friends here
Send a message via AIM to 02gt
I have an issue that has come up with my set up. I have 19x8 with a 35 off set,225/35/19, kyb agx shocks, and prokit springs. My rear has started to hit the rear upper control arm. It has damaged both rear tires. I wanted to know if a set of H&R 5mm wheel spacers will clear the control arm without me having to roll the fenders because I have shine street fender flares? There is 1 inch between the tire and upper control arm, 2 inches of space to line the tire up with the fender flares, and 1/2 inch of space between the top of the tire and fender. Thanks for any help.
02gt is offline   Reply With Quote Quick reply to this message
Old 11/26/2009, 08:31 AM   #130 (permalink)
bad mojo's Avatar
with the proper fender work, the widest is 9".
18x8.5 +45 will fit without rubbing.
Old 11/28/2009, 08:24 PM   #131 (permalink)
Iconzx6r's Avatar
Vehicle: 04 GTS
^looked awful though. Stuck out from fenders about a half inch. I'll just go 18x8.
Old 01/19/2010, 11:51 AM   #132 (permalink)
gencoupe can pretty much be considered an idiot by all
What how can you be rubbing?
35offset with the 225 tire should give you room from what ive calculated.. are you constantly rubbing on the control arm or at certain times?
I've got a similar setup with progress springs so about a 1.8" drop in the back.
I will be running 235/35/19 19x8 +40 offset in the rear, anyone see that being a problem? was planning to use a 5mm spacer if needed.. thoughts?
gencoupe is offline   Reply With Quote Quick reply to this message
Old 01/29/2010, 04:41 PM   #133 (permalink)
da1nonlynap : who are you?
Alright guys, unfortunately I need some new tires. I don't have a lot of knowledge on this topic so I was hoping for some help and recommendations.
I'm currently running Bf Goodrich G-Force T/A KDW's 225/40zR18 tires with Enkei CDR9 18x7 +40 offset wheels. I wanted to get some different tire's because those are going to cost me a arm and a leg. I was talking with the manager at firestone and he recommended the Falken Ziex ZE-912 225/40R18 92W. He chose those because that's what they had there but yeah. I was wondering if you guys could recommend any tires to me that won't completely break the bank but still perform.
I was also wondering if moving up to 235/40/18's would work and if it would give me a slightly smoother ride.
Thanks guys.
da1nonlynap is offline   Reply With Quote Quick reply to this message
Old 01/31/2010, 03:40 PM   #134 (permalink)
smartdog126 needs to be reminded to breathe.
can someone pm helping me with the off set please
my question is i have a 2001 eclipse RS and im looking and changing the stock rims to black rims or wheels and i need help with the offset for the 2001
as said before was
"actory GT wheel spec: 17x6.5" ; +46 offset ; 5x114.3 ; 67.1mm centerbore (applies to all 2000+ Eclipse models)"
does that offset apply to me since i have a RS not GT?
smartdog126 is offline   Reply With Quote Quick reply to this message
Old 02/22/2010, 09:06 AM   #135 (permalink)
Hola
Blade970's Avatar
Vehicle: 2003 Eclipse GT
Blade970 has a few friends hereBlade970 has a few friends hereBlade970 has a few friends hereBlade970 has a few friends hereBlade970 has a few friends hereBlade970 has a few friends hereBlade970 has a few friends hereBlade970 has a few friends hereBlade970 has a few friends hereBlade970 has a few friends here
Quick question. 1st post states that bolt pattern must be 5-114.3 Was on tirerack and when it brings up tires that will fit the 3g, 1 I am looking at shows bolt pattern as 5-114. Is tirerack wrong, or is the .3 small enough that it wouldn't matter?
Blade970 is offline   Reply With Quote Quick reply to this message
Old 02/22/2010, 09:15 AM   #136 (permalink)
It matters. Call and ask, maybe they labeled it wrong.
Old 03/04/2010, 08:38 AM   #137 (permalink)
travion's Avatar
Vehicle: 03 eclipes gts
travion : who are you?travion : who are you?travion : who are you?travion : who are you?
I'm trying to get some Tenzo DC-6 18x8 5x100-5x4.5/114.3 +35 or Tenzo DC-5 18x8 5x100-5x4.5/114.3 +37. Wheel this fit without rubbing running on a 225/40/18? When I put in my model car on the website it says +45 but I know that in a lot of cases cars are running on lower offsets as I can see in above post.
SN: my car is lowered on tein ss-p coilovers.
travion is offline   Reply With Quote Quick reply to this message
Old 03/04/2010, 08:38 PM   #138 (permalink)
FeelsGoodToBeGangsta
Gangsta_Man's Avatar
Vehicle: 2001 GTP
Gangsta_Man has a few friends hereGangsta_Man has a few friends hereGangsta_Man has a few friends hereGangsta_Man has a few friends hereGangsta_Man has a few friends hereGangsta_Man has a few friends hereGangsta_Man has a few friends hereGangsta_Man has a few friends here
Yes you will be fine Travion. Get the +35 offset
Please wait while I attempt to care...
Gangsta_Man is offline   Reply With Quote Quick reply to this message
Old 03/04/2010, 09:43 PM   #139 (permalink)
travion's Avatar
Thanx man, I appreciate it!!
Old 03/15/2010, 11:01 PM   #140 (permalink)
Vehicle: 02 Eclipse GT
Louis : who are you?
Originally Posted by AndrewJ View Post
I ended up going with 18x8 w/ a 40 offset and got the 'full' look I was trying to achieve. My previous wheels were 18x7.5 w/ 40 offset; I didn't realize that the .5 would appear to make a difference.
I ended up installing a set of the Enkei RPO3's with a set of Toyo TR1's - 225x40 18. The clearance was fine.
Not sure how to post pics so this is a second attempt...
A
Did you use any kind of spacers or did it just fit w/out any spacers?
Louis is offline   Reply With Quote Quick reply to this message
Old 03/15/2010, 11:28 PM   #141 (permalink)
Exclamation 18x7.5
Would they fit on a 2001 RS? And if so would I need spacers or something if I went with a 225/40/18? Cause the guy I'm buying them from seems to think it would be fine if I just threw them on w/out any spacers or any thing, not trying to be a noob but I'm just not sure cause I think they look good and all but don't wanna go killing myself of someone else behind some rims. The only reason I ask about the spacers is because on the chrome rims I had on there they used spacers and the where 18's as well. Please help, I'm looking to buy the rims and tires in the morning, thanks in advance.
Photobucket
Price is $250 for the set because all the tires need to be replaced. Or should I just spend the money and buy new, all comments welcome pls and thank you.
Old 03/27/2010, 09:44 PM   #142 (permalink)
Jimmi's Avatar
Vehicle: 01 EclipseGT SDS, 08 EVOX
Jimmi : who are you?Jimmi : who are you?Jimmi : who are you?Jimmi : who are you?Jimmi : who are you?
Question about wheel fitment. I have 18 x 8.5 +38s that came off my evo...curious about fitment with wide (different manufactureres make wider tread width than others) 225s or 235s on prokit springs. I have seen where at least one member has similar set up and gotten them to work.
Opinions?
Jimmi is offline   Reply With Quote Quick reply to this message
Old 04/02/2010, 03:12 AM   #143 (permalink)
Vehicle: 2001 GTP
Photobucket
99% of the time an 18" wheel fits the eclipse just fine, unless it is really wide. Do you have better specs? like how wide the wheel is, what offset?
225/40/18 work almost always, but the specs above are needed to be certain
Old 04/06/2010, 06:44 PM   #144 (permalink)
Rageful is similar to TE
18"x 8.5", comes in offsets: 20, 32, 35, 38, 45.
planning to go with 225/40/18 tires
Which offset would look/fit best on this setup? I'm currently leaning on 32.
would I have any issues with the 8.5" width? only width choice on my desired wheel.
Rageful is offline   Reply With Quote Quick reply to this message
Old 04/17/2010, 04:49 PM   #145 (permalink)
bad mojo's Avatar
+32 is what i would use.
it'll be flush with the rear fenders. the front will stick out past the fender, but will still be flush with the side of the car...this is because the nose of the 3g isn't as wide as the rest of the car.
imo, it's not a bad look. if you don't like it, roll the front fenders. problem solved.
if you go with +32, may i suggest NOT using a 225 tire. 255 will look much better and fit square on the wheel. it won't rub.
Old 04/26/2010, 10:23 PM   #146 (permalink)
Vehicle: 00 Eclipse GT
Not0rious76 : who are you?
nvm can delete
Not0rious76 is offline   Reply With Quote Quick reply to this message
Old 05/11/2010, 04:27 PM   #147 (permalink)
Slanderous's Avatar
Vehicle: 2008 Lancer Evolution
Slanderous : who are you?Slanderous : who are you?
Send a message via MSN to Slanderous Send a message via Yahoo to Slanderous
Ok so I saw some Motegis I liked, but they are a 19 inch wheel. Offset is 30 and its 9 inches wide.. not gonna work right?
The reason I asked is because I can only find them in a 17 and a 19.. and I dont really want a 17.
Thanks.
EDIT: Also lowered.
Slanderous is offline   Reply With Quote Quick reply to this message
Old 05/15/2010, 10:45 AM   #148 (permalink)
bad mojo's Avatar
Thanks.
EDIT: Also lowered.
motegi makes a 9 inch wheel?
what model is it?
Old 05/26/2010, 05:28 PM   #149 (permalink)
Slanderous's Avatar
what model is it?
sorry about the late response, its the touge. heres an ebay link to it
19 Inch Black Wheels Rims motegi touge 5x4.5: eBay Motors (item 110503125086 end time Jun-03-10 16:34:45 PDT)
Old 06/12/2010, 01:39 AM   #150 (permalink)
EclipseRider can pretty much be considered an idiot by all
Hey guys what brands would you suggest for a all season tire?
how are yokohama?
EclipseRider is offline   Reply With Quote Quick reply to this message
Old 06/12/2010, 07:40 AM   #151 (permalink)
Yokohama Avid are good all season tires.
Old 06/15/2010, 06:35 PM   #152 (permalink)
xOMidEclipse's Avatar
Vehicle: 2000 GT
xOMidEclipse : who are you?
Photobucket
I have the motegi's on my 01, and they fit fine!! My tire size is 225/25/17 so you should be fine!! I also role on nankangs!! Cheap but good all year around, even snow buy from discount tire and get the replacement coverage! It will do you good if you hit a pot whole!!!!!
Proud owner of
2001 GS sold
2000 Gt daily drive
xOMidEclipse is offline   Reply With Quote Quick reply to this message
Old 06/15/2010, 11:01 PM   #153 (permalink)
travion's Avatar
I've found a set of wheels that im am actually going to purchase this time. They are 18x8+35 up front and 18x9+41 in the rear. Now I believe they should fit with know problem the only thing that has me worried is that in order for them to fit a 08 civic si coupe they needed a 3mm spacer for the 18x9+41 wheels in the rear. The reason for the spacer was so that it would rub up against the suspension. As far as I know looking at wheels on the civic forum there offset are very similar to what we run over here between 35+ to +42. Any suggestions?
Old 07/13/2010, 12:18 AM   #154 (permalink)
ml2lp can pretty much be considered an idiot by all
hey guys i have a gts i will be running 225/35/19 tires. rims r 19x8.5 if i get 38 offset n probably 19x8 with the 45 offset. i plan on running s techs. do u think i will rub. thanks 4 help.
ml2lp is offline   Reply With Quote Quick reply to this message
Old 07/13/2010, 12:38 AM   #155 (permalink)
Tx4Codeman's Avatar
Vehicle: Lure 13.5
I have 225/35/19 on a 19x7.5 and I rub, so Ya.
. Please
Old 08/03/2010, 06:21 PM   #156 (permalink)
eclipseboy200's Avatar
Vehicle: 2000 eclipse gt
eclipseboy200 : who are you?
would 18x8.5 with a 35mm offset rub what tires would i need, im not lowered yet. and how far would they stick out?
eclipseboy200 is offline   Reply With Quote Quick reply to this message
Old 08/04/2010, 08:49 PM   #157 (permalink)
can someone help me out, I'm not good at figuring this out. I searched I dont understand it. Hope i posted in the right thread
Old 08/14/2010, 11:37 AM   #158 (permalink)
Jimmi's Avatar
I have 18 x 8.5 +38 off my other car and they stuck out about 1/2 inch in the front (~12mm) which looked a little goofy...but was flush in the back though.
I ended up going with 17 x 8 + 40 with a 3mm spacer to clear the brakes making it +37 and with -1.3 camber in the front and -0.5 in the back that with 235 tires makes it flush in the front and close in the back. This set up is about 8 mm or around 1/3 of an inch more in board than 18 x 8.5 + 35.
[IMG]DSC02572[/IMG]
[IMG]DSC02571[/IMG]
[IMG]DSC02728 [/IMG]
Old 08/14/2010, 11:59 PM   #159 (permalink)
linlan's Avatar
Vehicle: 2000 GS
linlan : who are you?
Ok, quick question. I am doing autox recently. Can I run 225/50/16 on stock gs wheel? I have Koni+KYB/Tein s tech setup? How about RPF1 16x7+43? I want to be able to run in DSP so larger wheel is not the opinion.
Thanks.
linlan is offline   Reply With Quote Quick reply to this message
Old 08/30/2010, 06:27 PM   #160 (permalink)
n00b
riced3g's Avatar
Vehicle: '01 eclipse
riced3g needs to be reminded to breathe.
Im going hellaflush!
riced3g is offline   Reply With Quote Quick reply to this message
Old 09/11/2010, 04:38 PM   #161 (permalink)
2011's are gay
White Knight's Avatar
Vehicle: 03 Eclipse GTS 6G75
White Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by allWhite Knight seems to be well-liked by all
thinking of getting 18x8 +35 with 225/40 tires, if i were lowered on agx + s-tech would this rub during both normal driving and hard cornering at the track? any help is appreciated
White Knight is offline   Reply With Quote Quick reply to this message
Old 09/16/2010, 01:56 PM   #162 (permalink)
2011's are gay
also, could i run a245/40 or even a 255/40 tire? or would i need to run a 35 series if i go that wide?
Old 09/16/2010, 03:49 PM   #163 (permalink)
WN - It shouldn't rub with a 25 series tire. I have 235s and they rub when the wheel is locked either way, granted I'm on 17s. Also, I'm lowered on S-Techs. I have a feeling 245 and up will rub a lot.
Old 09/16/2010, 05:37 PM   #164 (permalink)
2011's are gay
i'm on 225/45/17 and don't rub at all but i want to move to 245/40/18. i think offset is gonna play a huge roll. time to bust out the calculator. i'm on 17x7.5+45 right now and going to 18x8+35
Old 09/16/2010, 05:38 PM   #165 (permalink)
^^ If I'm not mistaken your new setup will protrude an additional .5"+10mm from where it is now.
Old 09/16/2010, 06:34 PM   #166 (permalink)
2011's are gay
i'm not worried about that, just wanted to know if i would rub or not. it looks like these new wheel/ tire combo will be .2 in taller but the same inside clearance, so i think i should be ok as long as that extra .2 doesn't hit anything
Old 09/16/2010, 06:40 PM   #167 (permalink)
Ph.D > me
Vehicle: '04 TSX ; '07 G35x
Phil should be considered a regularPhil should be considered a regularPhil should be considered a regularPhil should be considered a regularPhil should be considered a regularPhil should be considered a regularPhil should be considered a regularPhil should be considered a regularPhil should be considered a regularPhil should be considered a regularPhil should be considered a regular
Wrong. .25" + 10mm. Half of the difference will be on the inside and the other half will be on the outside.
Phil is offline   Reply With Quote Quick reply to this message
Old 09/16/2010, 06:59 PM   #168 (permalink)
Ph.D > me
18"x8" +35 won't be much different than this (just 5mm more pushed out past the fender):
In terms of running a 245/40-18...that is just way too tall of a tire if you're going to worry about rubbing. Combine that size tire with an 18x8 +35 wheel and I can guarantee that you'll rub up front if you're lowered at all. Hell, even at stock ride height I'd be willing to gamble that you'd still rub with that wheel/tire combo.
If I may, I will say that if you want to run a 245mm tire and your reason is solely for added grip, can I suggest that you just pick stickier tires in either 235/40-18 or 225/40-18? For example, when I went from 235/45-17 Yokohoma ES100's to 225/45-17 Michelin Pilot Sport PS2's, I not only eliminated almost all of my rubbing issues but I also had a ridiculous amount of extra grip.
Old 09/16/2010, 08:33 PM   #169 (permalink)
2011's are gay
thanks for the info both of you. i'm going to run a nitto nt-05 tire, i've had Michelin pilots before and hated them so bad i tried to wear them out, so Michelin are out of the questions. i have dunlop direnzza z1 starspecs right now and love them and i'm gonna give nitto nt-o5 a try and maybe nitto invo. any other tire suggestions would be appreciated, something to daily drive during the summer and take to the road course and drag strip on occasion, something with great cornering grip. oh, and under 200 bucks. thanks
Old 09/16/2010, 09:11 PM   #170 (permalink)
I realized that after I posted.
Old 09/16/2010, 09:18 PM   #171 (permalink)
Ph.D > me
Huh? Which Pilot's were you running? Pilot Sport, Pilot Sport PS2, Pilot Sport A/S (400 treadwear), Pilot Sport A/S+ (500 treadwear)? I had the opportunity to run both the PS2 and 400-rated All-seasons and loved both of them (but the PS2's moreso for obvious reasons).
Old 09/16/2010, 10:10 PM   #172 (permalink)
2011's are gay
Michelin Pilot HX MXM4
Old 09/17/2010, 08:19 AM   #173 (permalink)
Ph.D > me
Ahh, yeah, those tires suck. They came stock on both my '04 TSX and my 2010 TSX V6 but you have to realize they're a "touring" tire and are designed specifically for a super-smooth and quiet ride and really not much else. Any of the other tires I mentioned will be a night-and-day difference compared to the MXM4's, especially the Pilot Sport 2's.
Old 09/18/2010, 09:19 PM   #174 (permalink)
2011's are gay
what about 18x9 +15 would these rub or stick out enough to look retarded?
Old 09/18/2010, 09:33 PM   #175 (permalink)
Woah! Those would protrude a substantial amount, especially in the front.
Old 09/18/2010, 09:55 PM   #176 (permalink)
Ph.D > me
Yeah, that would protrude nearly 2" past the fenders.
And I'd hate to think about how much stress that would put on the wheel bearings..
Old 09/19/2010, 11:36 AM   #177 (permalink)
2011's are gay
ok,those are out of the question, looks like i'm going 18x8 +35 w/ 235-40 nitto nt-05 tires
Old 12/30/2010, 06:39 PM   #178 (permalink)
Dimitracos's Avatar
Dimitracos : who are you?Dimitracos : who are you?Dimitracos : who are you?Dimitracos : who are you?
Guys, need an advice: I got R18 8.5J ET20. Which tire size I should better choose to avoid rubbing, 235/40 will be fine ? As I understood in front I will have to use 20mm spacers
Boosted RS owner
Dimitracos is offline   Reply With Quote Quick reply to this message
Old 03/04/2011, 10:54 PM   #179 (permalink)
Kimosabe
Masta560's Avatar
Masta560 is well-liked by manyMasta560 is well-liked by manyMasta560 is well-liked by manyMasta560 is well-liked by manyMasta560 is well-liked by manyMasta560 is well-liked by manyMasta560 is well-liked by manyMasta560 is well-liked by manyMasta560 is well-liked by manyMasta560 is well-liked by manyMasta560 is well-liked by many
Hey, I'm looking at some 17" wheels with an offset of 40+ and I plan on putting 225/45-17's on. Will that look alright? Unfortunately I know nothing about wheels.. thanks
Masta560 is offline   Reply With Quote Quick reply to this message
Old 03/05/2011, 09:59 AM   #180 (permalink)
Kimosabe
Masta560's Avatar
Anyone?
