Hey, I have an odd problem. If this exact problem has been addressed before, please direct me towards the right thread. I've searched around, and haven't found anything that fits this exact problem.
I have a 2000 GS Auto, 100k miles, and the only mod is a short ram intake. I recently just changed my plugs and wires, and after pulling out the old ones, realized they were wayyy overdue. I went with Pulstar Plugs and NGK Wires. Well ever since I changed them out, I've been having an odd sputtering at low rpms. When I first start the car, it idles just fine at around 750, with no problems. The second I click into gear, the idle drops to around 600, but it feels like it's sputtering and the car shakes. Then if I let off the brake and push in the gas, it starts sputtering even worse, and shakes violently, but only for a couple seconds, and after I push in the gas harder and the RPMs rise, then it goes right back to normal. It will also sputter the same way after sitting at a stoplight for a while.
My initial thought was that it was misfiring, but then a mechanic friend of mine said that he thinks it's not getting enough gas. The coughing it does kinda is the same sputtering a car will do when it's running out of gas. I've also run out of gas a couple times in the last couple years, and run with the gas light on several times.
As of right now the car is driveable, and doesn't seem to be getting any worse gas mileage, which also makes no sense whatsoever. I'm not getting a SES light or any lights on the dash indicating any problems.
What does the problem sound like? Fuel pump, coil problem? What should I look for next?
