Can not get front bleeder screws to open to fully bleed brakes. Put in new wheel cylinders. Removed brake line to bleed but still some air in lines . Not sure what else can do besides get new Calipers to get all air out of lines?
Changing wheel hub this weekend & Tie Rod End. Think needs least 2 tires, maybe 4. Did not get alignment after first Time Rod End change last year. Probably should get alignment after Tie rod & Wheel cylinder change?
Still rides & runs pretty well for being over 20 years old.
Seems like back end needs tightening up, part replacements. Guessing much of rear suspension is factory. Would like to keep & do overhaul. Kind of scared to to overhaul/ new suspension parts because not sure if rust rot. Owned for almost 3 years. 223k miles. New timing belt kit w water pump, wheel cylinders, 2 tires and not much really, been strong car. American in my opinion.
Code for O2 sensor
Needs new exhaust flex pipe
Was wanting to cut Converter off because can smell inside car sometime. Sure factory converter so probably clogged/bad performance & county live in does not inspect for them. Anyway to remove converter &/or gut/remove material inside ? Or would this help gas milage/ performance any or hurt?
Think needs some intake/ throttle body cleaning. Not sure about cleaning MAF because cans say not to use on Mitsubishi.
Have not been wanting to fix unless broke bc seems to put pressure on other parts to break/need replacement. Also money, parts are cheap but can not do extensive labor/repairs myself or have all tools needed to do.
Any tips or tricks or cheap repairs should think about next or be thinking about. Thanks for the knowledge if have any input .
Code for O2 sensor
