1 - 1 of 1 Posts
Hi all, making my first post because I’ve run into a bit of a wall for my research here. I have a 2004 dodge stratus coupe with the 4G64 7 bolt engine. I have a long list for the build but the focus of this post will be on the engine. I plan on building the 2.1L destroker (4G63 head on the 4G64 block, 88mm crank, and 156mm rods) and then smacking a turbo on it. I haven’t even started researching good turbos for this set up and I plan on keeping it fwd for the sake of my sanity. Can you run a 2.1L destroker with out a turbo? How would this effect oil capacity? How would I go about building the trans so it doesn’t turn to dust? What are some tips for a build like this? What do I need for the turbo? Is there anything that I will need that I’m not thinking of?
1 - 1 of 1 Posts
