2-byte Load, RPM & Airflow inside (ECUFLASH)
I compiled all this info from various locations and mainly EVOM. If you guys see anything else please feel free to chime in. I will be testing this tommorow. All these codes are for Flashblues 94170008 ROM which is a modded EVO Viii rom for our cars.
You will need to first go into to your rom hex file and add the tables for rom as listed below. Once done you will have to open ecu flash and make the changes in the new tables as instructed below
For 2-byte load, we need to change the numbers that appear in the new single cell maps created, 00 and 01. To alter an entry press the = key, a box will then pop up. For 00, change the number to 35164. For 01, change it to 35165. Save your ROM and then upload it to your ECU (please also note that the burn sequence will take significantly longer that you'd normally expect, don't be alarmed
For 2-byte airflow, we need to change the numbers that appear in the new single cell maps created, 02 and 03. To alter an entry press the = key, a box will then pop up. For 04, change the number to 35258. For 05, change it to 35259. Save your ROM and then upload it to your ECU (please also note that the burn sequence will take significantly longer that you'd normally expect, don't be alarmed
For 2-byte RPM, we need to change the numbers that appear in the new single cell maps created, 04 and 05. To alter an entry press the = key, a box will then pop up. For 04, change the number to 0x893A. For 05, change it to 0x893B. Save your ROM and then upload it to your ECU (please also note that the burn sequence will take significantly longer that you'd normally expect, don't be alarmed
EVOSCAN
For those of you who are EVOSCAN and ECUFLASH guru's add your 2 cents if you see anything off here.
HTML:
<table name="00 2-byte load high " address="38062" category="MUT" type="1D" level="1" scaling="uint16" />
<table name="01 2-byte load low " address="36066" category="MUT" type="1D" level="1" scaling="uint16" />
<table name="02 2-byte Airflow High " category="MUT" address="3806A" type="1D" level="1" scaling="uint16"/>
<table name="03 2-byte Airflow Low " category="MUT" address="3806E" type="1D" level="1" scaling="uint16"/>
<table name="04 2-byte RPM high " address="38072" category="MUT" type="1D" level="1" scaling="Hex16" />
<table name="05 2-byte RPM low " address="38076" category="MUT" type="1D" level="1" scaling="Hex16" />
EVOSCAN
HTML:
<DataListItem DataLog="N" Color="" Display="2-Byte Load Mod 00/01" LogReference="LoadMUT2Byte" RequestID="00" RequestID2="01" Eval="0.3125*x" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="500" ChartMin="0" ChartMax="500" ScalingFactor="1" Notes=""/>
<DataListItem DataLog="Y" Color="" Display="2-Byte AirFlow Mod 02/03" LogReference="AirFlow2Byte" RequestID="02" RequestID2="03" Eval="6.29x/64" Unit="Hz" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="3000" ChartMin="0" ChartMax="3000" ScalingFactor="1" Notes=""/>
<DataListItem DataLog="N" Color="" Display="2Byte RPM Mod 04/05" LogReference="RPMMUT2Byte" RequestID="04" RequestID2="05" Eval="1000*x/256" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="8" ChartMin="0" ChartMax="80" ScalingFactor="0.1" Notes=""/>
