1 - 3 of 3 Posts
i just recently went through a month without my car because the tire shop<------:fawk: i went to blew up my motor. there insurance company coverd everything so i did not have to spend a dime. they found me an '01 motor with 60,000 less miles then mine had originally had. :) :)!!!! so i made out like a bandit. i also made them do it at the local mitsubishi dealer so it would be done correctly.
now the questions.... i am running an '00 computer to an '01 motor...hmmmm is that alright? from wut i know it shouldnt be to big of a deal unless i wanna tune then im outa luck. also is there an o2 sensor simulator for our cars? and whar can i get it?
Ask the dealer. They may have swapped out the ECU as well so that it matched the engine. Regardless, there should not be a problem using an 00 ECU unless you need to tune via ECUFlash.
1 - 3 of 3 Posts
