1 - 3 of 3 Posts
So I watched all the videos to be found about how to do it. Everything is off but can’t get the 14mm bolt off the one on top. The nut has been split and removed but the long bolt is stuck. Any suggestions?
44040
44041
Discussion Starter · #2 ·
@Bitter I joined because I think you are a car whisperer lol please any suggestions on how to get my baby running again
So I watched all the videos to be found about how to do it. Everything is off but can’t get the 14mm bolt off the one on top. The nut has been split and removed but the long bolt is stuck. Any suggestions? View attachment 44040 View attachment 44041
That long bolt has some pressure on it from the weight of the alternator, that is why it's so hard to get out.
It was so difficult when I did my timing belt and other belts.
You going to need to get a screwdriver or a wrench between the plate that's to the right of that(where the bolt goes), through and try relieve some weight off that bolt. While you're doing that, try to push out the bolt out with a short screwdriver or even a smaller bolt.
Spray some lube so it'll come out easier.
Someone may have an easier way, but that's how I did it.
1 - 3 of 3 Posts
