1 - 2 of 2 Posts
Driving down the road seems fine. The car has virtually no rust and only has 80000 miles on it. BUT. When I go over bumps or a rough road it literally feels like the right front is going to fall off. The whole front seems to sway like the tire is about to pop off. I checked the lugs and they are all right. Looked underneath and everything is rust free and nothing broken or leaking. Tires are new. Any idea what it might be?
Check your suspension. Something could be loose or worn out. Also check to make sure your struts aren't blown. After you're done, have your car aligned.
1 - 2 of 2 Posts
