1 - 2 of 2 Posts
respectful noob
So I was just looking for a battery on craig's list and I found this. Can I use any of this on my GT?
This eagle talon (mitsubishi eclipse) is still complete and being offered first as a turn key race car. If not sold then we'll part it out. It has a 10 point roll cage (built by Kennedy Racecars), 5 point harness, master cutoff switch in the back, window net and much more..The car was built to run the NHRA Sport RWD class and made 687whp @27psi off the nitrous on Mac Autosports Dyno..It still has some of the interior left inside, i.e. door panels, working dashboard, head liner. Below is a list of the parts on the car that will be up for sale if not sold as a whole. The asking price for the car is $24,000
*AEM ems #1310 w/ wideband single channel controller: $1200
*RC Engineering 1000cc injectors: $300
*Walbro 255gph fuel pumps (x2): $60 each
*Aeromotive fuel pressure regulator: $110
*ZEX dual bottle direct port nitrous system: $750
*MSD DIS-2 Ignition System: $250
*ARC Ignition System: $200
*Hayabusa coil packs(x4): $220
*800HP 2.0L longblock: $4200 for AEM cam gears & new oem t belt add $200
*Arias ceramic coated pistons
*Crower Rods
*Calico (ACL)coated bearings
*ARP Main & Head studs
*Balance shafts removed
*Balanced rotating assembly
*New oem oil pump
*New oem water pump
*All new oem seals
*Metal head gasket oem 4 layer
*Cylinder headwork done by Heads by Drew
*5 angle valve job
*Intake & exhaust portwork
*Polished combustion chambers
*Ferrea dual valve springs (10,000 rpm)
*Ferrea ss 1mm+ valves
*Brian Crower 280deg. cams
*Big bore 3rd gen lifters
*Valve cover with -12AN fitting welded to it for the catch can
*GT3582R Turbo w/.82 a/r T4 3"V-Band exhaust housing: $900
*Turbo oil & water lines $100
*DNP T4 twin scroll exhaust manifold: $450
*Tial 44mm wastegate polished: $300
*Magnus intake manifold 7bolt head w/Power 75mm throttle body: $550
*Custom Alternator relocation brackets, tensioner & idler pulley 2g: $250
*Turbo back 3" SS tig welded exhaust system w/ vibrant rear section: $450
*Intercooler Kit 12"x24"x4" 2.5" hot side piping, 3" cold side, all tig welded
aluminum w/ HKS bov: $700
*Transmission fully built (specs available upon request): $1500
*ACT clutch 2900lbs 6-puck sprung: $250
*Optima yellow top" $100
All parts are in great shape many of them are new with not even 20 miles on.
I'm sure there must be some parts I forgot to list so if you don't see what you're looking for here, feel free to call and ask.
TxTuning.com
I've read optima red/yellow batteries are great for reducing the light dims from systems. I'll leave the rest to the experts.
1 - 2 of 2 Posts
