1 - 3 of 3 Posts
Any recommendations for a headgasket for a 2003 3.0 GTS. Almost done pulling everything apart and about to get parts to install. Recccomendations needed
Stage 1 SDS @11+ psi
Yeah, stay with the stock head gaskets. I used 1999 3000 GT VR-4 head gaskets as my engine is not stock. Those are pretty thick and can lower your compression so they're not really needed if you plan on keeping your engine OEM.
Did you check your heads warpage? The best way to ensure good head gasket seal is to make sure the block in your heads are decked.
1 - 3 of 3 Posts
