Its a single turbo set up. I'll be using a H1C turbo. I'll be keepin the boost at about 2.7 pounds for about a month after the install just to play around with the tune a bit, and than I'll be bumping it up to 5psi afterwards, it'll be staying at 5 till I build up my spare 3.5 block.
The details of my setup are as follows
H1C turbocharger
2nd gen side mount intercooler
38mm wastegate
manual boost controller
440cc injectors
walboro fuel pump (already installed)
custom turbo piping (will be done by a local exhaust shop)
ebay intercooler piping with non ebay couplers
I'll be using the stock fuel pressure regulator for my setup, I will be setting up the intake side as a "blow through" setup (alot may disagree with this type of setup, I have personally seen it set up this way in person and the guys car ran great.....so i'll be doing it that way too). As for the tune, I'll be using Ecu flash for tuning.
I currently have all that I need for my setup, except for the turbo piping and 440cc injectors. I'll be having the piping made approx. 2 weeks from now. I'll be buying the injectors hopefully this weekend, If not, definatly no later than wednesday of this comming week.
