What’s the cause of low Compression
Hey I have a 2001 2.4l iv asked recently on what’s wrong with it. Iv narrowed it down and replaced damn near everything but I have 30psi in each cylinder, and doesn’t start just cranks, Iv done the timing already and prob everything besides the valves and pistons and ring, what do you think the low Compression could be from?
Add a few ml engine oil to the cylinder. The oil helps seals the rings. Then run the compression check again. If pressure goes higher, the problem is your rings. If pressure stays the same, the problem is your valves or valve seals.
Stage 1 SDS @11+ psi
If your timing was way off during the initial start, you may have bent the valves. The 3gs are interference engines. After doing jelazar's suggestion, do a a leak-down test.
Buy a rebuilt or used engine long block due to it being the cheapest way to fix the problem.
