1 - 17 of 17 Posts
Resident Asshole
Indeed it does. Did Jimmy finally get you that last set of piping Russ?
Glad you asked.
If you guys need more pics let me know :)
Finally.... i asked for a pic like this in like my frist 20-30 posts!!
Thanks Tearstone!!!
More would also be great!
Resident Asshole
That piping sure looks like a derivation from the norm. Whose engine is that?
That is the piping design that Donny from Gulf Coast Turbo / AAI produced. I've seen several of those in person now. heh
This is how I did mine.
call me dumb, but assuming the charge pipe above the intercooler is the cool piping, did the length of to ic to tb piping affect the charge temps at all?
Discussion Starter · #13 ·
Thanks RULES appreciate it!! Has anyone used an intercooler with running both pipes on the same side for a shorter route?
Resident Asshole
Actually the FMIC found on my car is not from Hahns. It was custom made by Extreme Motorsports about 5 years ago.
A couple of notes about FMIC's now that I know more than I did then...
1) Normally FMIC's with the inlet and outlet on the same side suffer a tad in the efficiency department. FMIC's w/ the inlet and outlet on the opposite sides have less pressure drop and are more effective.
2) Length of piping has a direct effect on perceived lag of the turbo. The shorter the piping, the more responsive your turbo will be.
3) Sharp bends can negatively effect turbo response.
4) Couplers should not be used to make up bends. As much as possible, use only straight couplers.
1 - 17 of 17 Posts
