1 - 3 of 3 Posts
Hello! Let me start off by saying that I do not own an Eclipse anymore. I owned a 3G a while back but it had too many problems for my budget. However, I am needing some help from Eclipse owners as I know very little about the 4G63. I now own a 2006 Hyundai Tiburon GS. I bought this car for college because A.) It was cheaper and B.) I save a lot more money on gas than I did with my Eclipse Spyder GTS. I am in the early stages of planning an engine swap. However, i have done some research and am wanting to get a few pointers on my potential build. I have only had time to research parts for the engine but here's what I have:
< I plan to begin by rebuilding the engine and replacing as many gaskets and seals as reasonable
< I also plan to change out the harder-to-get-to sensors(such as crank positioning sensor)
< Also change out all fluids and filters
< Hot tank the block
< Resurface the head and many other tidy up tasks
Now for parts:
< Weapon R intake manifold
< DeastschWerks 1300cc fuel injectors
< Crower High performance cams
< Manley 86mm 9.0:1 pistons
< Manley I-beam rods
< Fp3065 turbo (or other, heard this is a good one to choose)
< Intercooler with custom piping
< CAI with custom piping
< Custom single-exit (or maybe dual-exit) exhaust
< Custom engine mounts
< Oil catch
< Megan racing short shifter
< AEM EMS V2
< Mishimoto radiator
Now, if anyone could give me some pointers that would be very appreciated(such as whether or not I should run an external wastegate setup)! My end goal is to get between 400 and 500 hp, if that helps. Thank you!!
I think you'd be better off going to an actual 1g/2g forum. This forum is mainly for 3g enthusiasts and the 1g/2/g forum is sort of an afterthought. Also a lot of evos had 4g63s so it's probably worth checking them out depending on what gen of that engine you are going with.
I registered for dsmtalk but I have to wait seven days to post because of some knid of lurker policy or whatever
1 - 3 of 3 Posts
