Radiator is in now but that picture gives you an idea of what removing the condenser can do for airflow.
His car has been sitting in his backyard forever, because he hasn't had time to work on it.
Just a side note: how did all your pully's get so rusty,I know you drive it in the northern winters, sorry!
Pharm - My AC compressor has been off for a while now. One of my shops just got rid of the whole thing, can't recall if they left the brackets though. Still have the lines in but those will be going too. Should look to see how they did it - I just know it's been gone with no special fabbing... :dunno:Clipse3GT, post some pics for others who have the SDS to see as a reference.
When I find my camera's battery charger, I'll snap a shot of the bracket.
Couldn't you use a slightly smaller belt around 45" or 45.5"? That would mean that the tensioner pulley would be higher up and far enough away from the other side of the belt.Technically you could use the belt w/o this bracket and pulley but I don't like how close the two belts then are, like less than 1/8" of clearance.
Doing this the belts are really close together probably a quarter/half an inch or something like that, but I don't have issues with them touching or rubbing. Ran it for the past two years this way and has been working fine. But the catch is to run a pretty tight belt, then use the tensioner minimally, since using it too much will cause the belts to touch.Technically you could use the belt w/o this bracket and pulley but I don't like how close the two belts then are, like less than 1/8" of clearance.
