1 - 10 of 10 Posts
so i'm almost done installing this sds kit.... but i don't have the spacers for the fuel rails.... any suggestions?
OMFG
:agreed:
They have a smaller part that protrudes on each side of them sot hat theyfit inside the recess on the manifold. I dont know if its the same for the V6 rails but this is how it is on the 4G rails.
I just grinded the two of them down so they are flat on one side. Put the flat sides together, and it was the perfect height. You hvae to grind accordingly though becuase each injector is different.
turbo? unf unf!
if you're doing it for DSM style injectors (450's to be specific).. or any upgrade that is a direct bolton for that car..
stacking two and making 2 sides flat will fit your injectors PERFECTLY :)
either electrical tape them together.. or glue em
worked great for me..
I used washers on top of the spacers.
The ones i got from RC were WAY too small for the 440's they came with.... Hence the washers
Ohh that's the problem :fawk: of course i did they were still to small
1 - 10 of 10 Posts
