compressor wasn’t running hooked up Freon gauge said it was low recharged it compressor kicked on but still blowing hot air what next need help thank you.
What do you mean when you say you recharged it? Did you use a vacuum pump to evacuate the system, then add freon? Or did you simply add freon to the system. If you just added freon, there's probably still air trapped in the system and it doesn't compress properly.
