Will a AEM Tru-Time Cam Gear help get more hp out of a 2001 Eclipse GS? (Im N/A)
GSMachinist · 4 Cylinder Beast Joined Jul 18, 2007 · 440 Posts Discussion Starter • #1 • Dec 16, 2007 Will a AEM Tru-Time Cam Gear help get more hp out of a 2001 Eclipse GS? (Im N/A)
0 04gsNA · Banned Joined Feb 1, 2007 · 4,408 Posts #2 • Dec 16, 2007 If you advance timing yes. But you will need to run higher octane fuel.
FlashBlueRS · Zero Resistance, LLC Joined Jan 14, 2003 · 1,948 Posts #3 • Dec 16, 2007 Ignition timing and valve timing are different. Advancing valve timing with the Cam gear will only shift the power band.
GSMachinist · 4 Cylinder Beast Joined Jul 18, 2007 · 440 Posts Discussion Starter • #4 • Dec 17, 2007 04gsNA said: If you advance timing yes. But you will need to run higher octane fuel. Click to expand... Logic said i have advanced timing cuz he flashed my ECU. What about AEM Pulleys?
kabob · More guns than sense Joined Jun 12, 2001 · 38,301 Posts #5 • Dec 17, 2007 Guy, do a search. In a nutshell, you're wasting your time with pulleys and cam gears on an otherwise stock vehicle.
