Wow, thats bad! Guess I got lucky being in the first group buy! They better stand behind it but as I mentioned in the other thread, I would contact Wesellcarparts as they are Megan's dist.. Make sure they are in the loop on this!
Yeah my coilovers are like the ones pictured above. I really don't see it as being that big of a deal. If megan did decide to fix the problem, the easiest way would be for them to supply new endlinks that fit.
I bought some new ebay endlinks, and they have not broken yet. If they do break, then I will try to make some endlinks with heim joints. They are pretty cheap. I belive the parts could be found at a place like below.
http://www.boomerangracing.com/Tie Rods & Rod Ends.htm
hey thanks that site is awesome.. i keep breaking the stock ones with the stock struts.. hmmYeah my coilovers are like the ones pictured above. I really don't see it as being that big of a deal. If megan did decide to fix the problem, the easiest way would be for them to supply new endlinks that fit.
I checked mine tonight, and the links and LCA have more than enough room. It is possible that you are having more of a problem because of the RMDSM sway bar. Just a suggestion, but you could always cut 1/2" out of the links, reposition them, and then weld the links back up. I don't think the heat from welding would cause any damage to the ends.I already got the insanely thick Moog endlinks. Im not worried about the endlinks breaking, im worried about not being able to leave the driveway. This thing is sooo far off that I cant even steer. The wheels only turn half way each direction, if I try to go further I just get stuck because the lower control arm and the stabilizer bar/link are binding up. Im not talking about the common problem with them side loading due to the bracket being welded at the wrong angle, my bracket is welded at the wrong heigh, its 1/2" too low, so in reality I either need them to send me the wright part, or end links that are 1/2" shorter.
The only thing that I do not like about going that route would be the lack of dust boot. There are dust boost available for rod ends, but I don't know where to get them or how they secure to the rod end. It looks like whiteline has some nice universal links with dust boots, but I don't know the price.hey thanks that site is awesome.. i keep breaking the stock ones with the stock struts.. hmm
Yeah I have been looking into that. The whiteline ones you posted are more of a heim joint rather than a link end. check these guys outI checked mine tonight, and the links and LCA have more than enough room. It is possible that you are having more of a problem because of the RMDSM sway bar. Just a suggestion, but you could always cut 1/2" out of the links, reposition them, and then weld the links back up. I don't think the heat from welding would cause any damage to the ends.
