Hi, I was wondering what are the most fundementaly important tools needed to succecfuly tune? My buddy with a turbo 4G64 (galant) told me that his initial tuning could be done by EGT and SAFCII hooked up only to the narrowband o2 sensor (no afpr, high imp injectors, ect). Can we intially tune this way as well (he has all the other required gauges)?
Also which of these two fuel setups would you guys recommend for a moderate 250ish whp:
1)
DSM Walbro 190lph fuel pump
Stock fuel rails
450cc low impedance injectors (peak and hold ~ dont really want to mess with a resistor pack and stuff)
2)
Walbro 255lph pump
Stock rails
RC 310 High Impedance injectors
The way I see it is that both setups can avoid the use of an adjustable FPR.
Thanks a lot for your help.
1)
Stock fuel rails
2)
Walbro 255lph pump
Stock rails
