1 - 7 of 7 Posts
Cone Killer
So the past four or five days, my car has been randomly dieing when I'd start it. It happened once after school, we charged it ad got the battery and alternator checked and both were fine. After charging it worked fine for a day, then did it again. Completley dead. Jumped it then, haven't had a problem for days. Then did it again today. Im not leaving anything on or anything like that. I need help:scratch:
Sounds like your Alternator is going bad. Its not charging the battery enough to start the car.
Sword at the Ready!
Hmm maybe a parasitic draw test? But start at the very basics, corrosion, loose terminals, bad grounds, etc. 8/10 its something simple such as those or the battery may have enough voltage but losing its cca, seen those false positives where someone checks just the volts and it seems fine or borderline but the cca is way down.
:agreed:
Cone Killer
We did a double check and the terminals were actualy pretty lose so we cleaned them and the posts and tightened them down and seeing if this works. So far so good I'm hoping its something simple like that at least.
1 - 7 of 7 Posts
