1 - 7 of 7 Posts
Thought i had it all figured out and beat then when trying to break the SDS in belt broke. Is this common? what Causes it? and what belts have you guys had success with?
Wanna be my Sheep?
usually the belt snaps because it was either overtightened or because it was installed improperly. I've had 2 belts break on me in the past 2 years, both broke right after I installed or reinstalled them. Overall, I've had great luck with the NAPA generic belts.
Boosted
the SDS can really stretch out a belt.
also i noticed many SDS owners are actually not tightening the belt enough on installs and thus the belt just gets thrown and tore up.
good rule of thumb on the install. TIghten the belt so you can twist the belt NO MORE than 60 degrees betweeen AC pulley and Crank pulley.
New Rider
If the belt breaks, then is there engine shut down or just SDS power loss? And is if fixed by a simple belt replacement?
Wanna be my Sheep?
The engine still runs fine, you just don't have the power of the SDS, AC, or alternator. As long as you have a battery with some juice in it, you'll be fine. And its all fixed by replacing the belt which is about a 30 minute task.
thanks for the reply's guys i put a new one in but couldnt really tighten it down real as i could barley get it on let alone make it tighter. but atleast this one i got has a 1 year warrenty.
Another cause of belt failure is making sure the alignment of the SDS pulley is perfectly in line with the other pulleys. It good easily jump a notch and start self destructing itself. (Personal experience)
1 - 7 of 7 Posts
