1 - 20 of 22 Posts
Lance Corporal
Ok, Im designing my own turbo kit and plan on going blow through using a GM MAF + Translator. Now I know on a suck through with our MAS you recerculate the BOV to the intake pipe before the MAS and turbo. But with the blow through do you still put it before the turbo or does it matter so long as it goes back before the MAF? Just something I thought about while sketching it out.
blow through:
Code:
[throttle body]===[mas]===[bov]===[blower]===[filter]
suck through:
Code:
[throttle body]===[bov]===[blower]===[recirc tube]===[mas]===[filter]
                    |___________________|
Lance Corporal
Huh? On the blow through diagram it dosent show where the recerc tube is. ANd you show the BOV before the MAS?
you do not want to recirculate if you blow through the mas, it wont do any good.
Lance Corporal
Ok so recerculation is not needed on a blow through. Thats cool, simplifies the piping. Also the BOV should be before the MAF? Thats fine too. I am gonna use a GM MAF.
well yeah you can do it but why? as long as you blow off before the air gets passed through the sensor its all good.
Ah yes...
Remember if you use a GM MAF, you will need a translator as well. One from a VR4 works and one from a 2G GST/GSX can be used.
Yes, the BOV must be before the MAF. :yesway:
New daddy
If you go with blow through then make sure that the BOV is not too close to the MAF. Also, I am not certain, but there probably is a certain distance the BOV should be from the compressor.
Lance Corporal
Discussion Starter · #13 ·
I drew it up it Paint. How does this look to yall? Its not exactly to scale but you get the idea. Also Im gonna ceramic coat the hot pipes so the dont rust.
Ah yes...
Nice job using paint :twothumb:
Looks good.
Kampfbereit
That's the beauty of the MAF, just blow through it and put the BOV between the MAF and the turbo.
Lance Corporal
Discussion Starter · #17 ·
WOW!!!! Im in heaven!!!! The 3G FI GOD just complimented me on my design. Thank you. That realllllllly means alot to me. Im being serious. :hug3: :hug3:
To HELL With Georgia
Tearstone said:
:lol: no no no no don't put me on a pedastal like that, I'm just a member like the rest of you all :)
I'm going to have to call :bsflag: on the whole "..just a member..." statement. You are more than just a member to all of us. :kiss: :wub:
And the drawing looks good. Good job sitting down and thinking things out for yourself! :yesway:
basicly you have two options with blow thru. atmosphere or recir, either works just as well
but remember that after the airs gone thru the intercooler, its cool air, and its been argued that if you recirc this "cool air" which can actualy now be COLDER then the outside air temp, if you recirc it its going to allow your intercooler to have to do less work, resulting in even cooler air temps ..
blow through option one :
Code:
                            |_____>> vent to atmosphere
Code:
                            |_____>> recirc to turbo inlet
suck through:
Code:
1 - 20 of 22 Posts
