1 - 10 of 10 Posts
Titanium Spork
dual halo's its pretty much agreed that they are the worst aftermarket headlights for this platform. Take it as a blessing and upgrade
not the worst (anzos are worse than dual halos) but the second worst.
i had them (well still do, but they are in the basement). when i upgraded to depos (that i then modified to HAVE dual CCFL halos) i found out what i was missing. the depos have a night and day better light output than the dual halos.
take this as a sign to go buy some depos, and give up on dual halos.
the amount of work to fix your headlight is not worth it. you will have to bake them open, HOPE the adjusters aren't broken (10 bucks says they are) put all the parts back where they go, and epoxy them back in, reseal (with new silicone) the headlight closed.... and still be stuck with the SECOND worst headlight available.
:agreed:
Manual Swapped!!
Thanks for the responses. I will definitley go and get those replaced for something else. ;)
there is a headlight thread, I suggest you check it out just to get an idea of what is out there and what some members have to say about them. Its a great place to get an idea
Get the depos. I just got a set and the fitment is perfect, paired with a set of 5000k H7 HIDs the output and cutoff flicker is superb. The two pairs of sonars I previously had, the rubber sealer around the headlight was sticking out in places like they didnt fit properly, But not with the depos. Also the depos required no modification whatsoever for the HIDs, unlike sonar. Bought them from Depo on amazon for 200, not some ebay knockoff :yesway:
1 - 10 of 10 Posts
