1 - 14 of 14 Posts
Hello All, it's been a while since I've been in the forums. But I ran into a problem with my 03 GT, the harsh winters and all the salt corroded and rusted my hood release cable. It broke right up in the hood latch assembly.
I couldn't get that hood open for love or money. I took it to multiple mechanics, and after monkeying with it, the said they would have to damage the hood to get it off.
Well, I found the solution and it's a lot simpler than you may think!!
All you need is a flashlight and a flat head screwdriver.
If you peek between the hood and front fascia (bumper) with the flashlight you'll be able to see the latch mechanism. Looking at the front of the mechanism you can see the U shaped bottom part of the latch. Near the bottom right side of the U there is a small vertical hole, just about the right size for the tip of that screwdriver I mentioned.
Stick the screwdriver in the hole at an angle (as if you were pointing the screwdriver at the passenger door). Then lever the screwdriver to the left, like you're flicking a big switch, and you'll catch the release mechanism, and the hood will pop up just as if you had pulled the release.
Then you can open the hood normally from there.
Enjoy! I hope this saves someone some time and trouble.
Edit: I've included a clearer photo.
All right please don't flame me for reviving a really old thread, but this just happened to me and i can't find the actual "vertical hole" so if anyone could take a shot of their latch mechanism and the actual hole it would DEFINATELY BE A LIFESAVER! :O i am desperate haha been looking an eternity with a flashlight and my screwdriver in my driveway...
please... help! :)
This just happen to me too! I've been trying to get this stupid hood open for almost a week now. I cant seem to get the right touch to pop the hood up. I am currently exploring other methodes...
couldn't find any other way of doing it. wondering if the screw driver should go threw that piece <a href="http://www.flickr.com/photos/[email protected]/8605069738/" title="2013-03-30 19.47.54-2 by Rylandw, on Flickr"><img src="http://farm9.staticflickr.com/8254/8605069738_888aaff3f5.jpg" width="500" height="374" alt="2013-03-30 19.47.54-2"></a>any feedback at all would help!
i put the small flathead into there and i pryed the screwdriver left,(pushed the handle to the right) and having one heck of a time.. is it supposed to take a lot of pressure to push it? im bending the screwdriver prying so hard
If the latch is seized it's going to be hard. The how-to assumes a working latch but broken cable. It sounds like your latch is seized solid (do to non use/not being lubed properly and regularly) and the cable broke because of a seized latch not a worn cable. Try a stronger screw driver and maybe hitting it with a hammer. See if you can get some penetrating oil soaked into the latch. Worst case you'll need to find some other way to get it open if the latch is totally seized solid, I don't even know how. Try a body shop?
Also try prying the other way too. The cable pulls the mechanism to the driver side, I think you're trying to duplicate that with the screw driver.
not saying your wrong but means the cable is due for replacement I would have just grabbed the cable and gave it a good tug out to the right and popa wohla.....
1 - 14 of 14 Posts
