Hi, im a nubie, but while driving last night my power steering belt snapped mid turn, lost steering and almost slammed into a parked car, i was just wondering if anybody else has had this problem or if its only cuz i have 99,000 miles on my car.
my elts have een squeeling during these snowstorms, but only when i am driving on the unplowed streets.Bitter said:you need to replace the timing belt if you havent done so already.
also a belt will squeel like a pig with its balls in a vice 99% of the time for a long time before it snaps.
no need to do that on the snow/ice, the tires spin freely :lol:Bitter said:get the tension on them checked. they may just be a little loose. if you brake torque do they squeel?
Harmonic balancers have no service life, you change them when they split.They don't "wear out" like other parts do, They're good one day and bad then next. If they go you know it because they come right part and then you have nothing.
You're either way over tensioning the belts or your PS pump is overloading it be it the pump or fluid being bad or you have some driving habit that facilitates major drive pressures in the steering rack. You could also have a tad tensioner pulley, if the bearings are shot it could be heating up or even locking up.
