1 - 20 of 179 Posts
Um... Yeah!?
Courtesy of various other members, and of course, our owner's manual:
Headlights (2) - H4 / HB2 / 9003
Foglights (2) - H3
Clock pod (3), temp controls (2), cubby hole (1) - 74
Gauges (6), rear corners (2) - 194
Rearview mirror (2) - Festoon 214-2 (44x10mm)
Front side markers (2) - 1157
Reverse (backup) lights (2), Rear turn signal light (2) - 1156
Third brake light (1) - 921
Trunk (1) - T-6 / H-223 / Festoon 3022 (31x10mm)
Rear side markers (2), license plate (1) - 168
Dome light - 168 WEDGE bulb
Stop and tail light (2) - 2057
2003-2005
Foglights (2) - H1
Um... Yeah!?
Discussion Starter · #2 ·
From MadCadder:
Sub-miniature Wedge base:
E37 - 14 volts, .090 amps, .50 MSCP, .80 MOL, .20 MOD, 2500 hr/life
37 - 14 volts, .090 amps, .50 MSCP, .80 MOL, .23 MOD, 2500 hr/life
74 - 14 volts, .100 amps, .70 MSCP, .80 MOL, .23 MOD, 1000 hr/life
(must be using an E37 or i had a bad size set of 74's)
Wedge base:
168 - 14 volts, .38 amps, 3.0 MSCP, 1.06 MOL, .40 MOD, 1500 hr/life
194 - 14 volts, .27 amps, 2.0 MSCP, 1.06 MOL, .40 MOD, 2500 hr/life
921 - 12.8 volts, 1.40 amps, 21.0 MSCP, 1.49 MOL, .62 MOD, 1000 hr/life
Single Contact Bayonet base:
1156 - 12.8 volts, 2.10 amps, 32 MSCP, 2.00 MOL, 1.04 MOD, 1200 hr/life
Dual Contact Bayonet base:
1157 - 12.8/14.0 volts, 2.10/0.59 amps, 32/3 MSCP, 2.00 MOL, 1.04 MOD, 1200/5000 hr/life
(I can't find any reference to a "T-6 H-223 12v-10w" bulb and mine calls it "A12V5W" [guessing 12volts/5watts] going out on a limb here and calling it a: )
8mm Festoon Base:
DE3021 - 14.0 volts, .24 amps, 2.00 MSCP, 1.10 MOL, .32 MOD, 1000 hr/life
(the volts is wrong, but the length and diameter is right)
Edit: Found it... brand is toshiba lighting.
HRA-8122 - 12.0 volts, 5 watt, 3.8 MSCP?, 1.14 MOL, .32 MOD, 1000 hr/life
MSCP or mean spherical candlepower
(not written in stone)
MOL: Module overall Length
MOD: Module overall Diameter
MSCP: Mean Spherical Candlepower (brightness vs. candle)
A few bulb conversions can be found at http://www.flippers.com/lights.html
Good, good.
The fog lights on the 00-02's are H3
on the 03-04's they're H1
Also of note:
The headlight bulbs are 60/55W
If installing higher wattage bulbs, it is highly recommended to upgrade the wiring harnesses.
I just wanted to make a note that "rearview mirror (2) - 194" is incorrect for early 3g. I have a 2000 and ordered 2 194's and they are not what is needed. The bulbs needed have conductors on both sides of the tube which is the light. Im not sure what the correct bulb # or size is.
Um... Yeah!?
I'll try to check on the sizes a bit later... but what kind of Eclipse do you drive? Spyder, coupe with sunroof, or coupe without sunroof?
Um... Yeah!?
GhettoVan said:
I drive a coupe with sunroof. If you know the size that would help a lot! thx.
btw, (http://autolumination.com/festoon.htm) this is the site Im planning on getting them from since I bought my interior blue size 74 LED's from there when I changed it out. So one of those should be the correct size. im just unsure which one. :confused:
The easiest way to check would be to go to your local automotive parts store (Autozone, Pep Boys, Kragens, etc.) with your bulb, and compare the sizes... That's what I'm going to do when I have some time, since the owner's manual only says "4CP," which is not very useful in trying to order online.
And since there seems to be some discrepancy on the sizes, can anyone with a 2001+ Eclipse please check your bulbs to see if the 168 Wedge Bulb or 194 bulb fit your dome lights?
Service Engine Soon
Anyone know what sizes bulbs are used in the sporty gauge cluster that illuminates the individual gears (1-2-3-4) My #4 is out and I'd like to have the bulb in hand before I pull the cluster out.
the tower......
another place to get really good L.E.D bulbs is superbrightleds.com ....the ones i got work very well,although i can't give you a bulblife estimate since the ones i have i just got....i have yet to change the ones under the guages(next weekend since the dash will be apart anyway..)but i've changed the cubby hole light in my car and the guage lights in the kenworth i drive for work...they look sweet...and they also offer some of the lights in a wide angle bulb setup..........good selection of colors too
bollocks
i tried this when i went to get coloured bulbs for there. they werent the right watage and blew out within a few days
superbrightleds.com & pjautomotive.com ...just to name a couple. Search around tho, many many people have done what your planing to do. Good Luck finding what your looking for.
The Risk
My clock pod bulbs and the cubby hole bulb for a 00 Eclipse GT Cali Spec Manual w/ Sunroof were size A37. I bought them from http://www.dav-electronics.com/products.htm . They're supposed to be direct replacement, but I had to file the circuit board a tiny bit for perfect fit. *was looking at wrong bulbs (the one for AC and another smaller one, instead of the two accessed by the back)* Hope I helped.
I also have a 2000 GT with sunroof, the stock bulb is 214-2 in the rearview mirror. You should be able to find replacements for those easily... :eek3:
1 - 20 of 179 Posts
