161 - 179 of 179 Posts
My LED,tail lights reverse, and side markers work just fine... though I do plan to seal the tail light housings with RTV clear silicone the way I did the clear bumpers... to rid them of condesation...p.s. the corners are not white but red now becuase cop pulled me over told me to put red ones in.
2000-2005 Mitsubishi Eclipse Light Bulb Fitment Application List
2000 Mitsubishi Eclipse Light Bulb Fitment Application List:
2000 Mitsubishi Eclipse High & low beam headlight uses 9003/HB2 bulb.
2000 Mitsubishi Eclipse Parking light uses 1157 bulb.
2000 Mitsubishi Eclipse Front turn signal uses 1157 bulb.
2000 Mitsubishi Eclipse Rear turn signal uses 1156 bulb.
2000 Mitsubishi Eclipse Tail light uses 2057 bulb.
2000 Mitsubishi Eclipse Stop light uses 2057 bulb.
2000 Mitsubishi Eclipse High mount stop light uses 921 bulb.
2000 Mitsubishi Eclipse Fog/Driving light uses H3-55W bulb.
2000 Mitsubishi Eclipse License plate uses 168 bulb.
2000 Mitsubishi Eclipse Back up light uses 1156 bulb.
2000 Mitsubishi Eclipse Front sidemarker uses 1157 bulb.
2000 Mitsubishi Eclipse Rear sidemarker uses 168 bulb.
2000 Mitsubishi Eclipse Dome light uses DE3175 bulb.
2000 Mitsubishi Eclipse Trunk/Cargo area uses DE3022 bulb.
2000 Mitsubishi Eclipse Instrument-general uses 74 bulb.
2001 Mitsubishi Eclipse Light Bulb Fitment Application List:
2001 Mitsubishi Eclipse High & low beam headlight uses 9003/HB2 bulb.
2001 Mitsubishi Eclipse Parking light uses 1157 bulb.
2001 Mitsubishi Eclipse Front turn signal uses 1157 bulb.
2001 Mitsubishi Eclipse Rear turn signal uses 1156 bulb.
2001 Mitsubishi Eclipse Tail light uses 2057 bulb.
2001 Mitsubishi Eclipse Stop light uses 2057 bulb.
2001 Mitsubishi Eclipse High mount stop light uses 921 bulb.
2001 Mitsubishi Eclipse Fog/Driving light uses H3-55W bulb.
2001 Mitsubishi Eclipse License plate uses 168 bulb.
2001 Mitsubishi Eclipse Back up light uses 1156 bulb.
2001 Mitsubishi Eclipse Front sidemarker uses 1157 bulb.
2001 Mitsubishi Eclipse Rear sidemarker uses 168 bulb.
2001 Mitsubishi Eclipse Dome light uses DE3175 bulb.
2001 Mitsubishi Eclipse Trunk/Cargo area uses DE3022 bulb.
2001 Mitsubishi Eclipse Instrument-general uses 74 bulb.
2002 Mitsubishi Eclipse Light Bulb Fitment Application List:
2002 Mitsubishi Eclipse High & low beam headlight uses 9003/HB2 bulb.
2002 Mitsubishi Eclipse Parking light uses 1157 bulb.
2002 Mitsubishi Eclipse Front turn signal uses 1157 bulb.
2002 Mitsubishi Eclipse Rear turn signal uses 1156 bulb.
2002 Mitsubishi Eclipse Tail light uses 2057 bulb.
2002 Mitsubishi Eclipse Stop light uses 2057 bulb.
2002 Mitsubishi Eclipse High mount stop light uses 921 bulb.
2002 Mitsubishi Eclipse Fog/Driving light uses H3-55W bulb.
2002 Mitsubishi Eclipse License plate uses 168 bulb.
2002 Mitsubishi Eclipse Back up light uses 1156 bulb.
2002 Mitsubishi Eclipse Front sidemarker uses 1157 bulb.
2002 Mitsubishi Eclipse Rear sidemarker uses 168 bulb.
2002 Mitsubishi Eclipse Dome light uses DE3175 bulb.
2002 Mitsubishi Eclipse Trunk/Cargo area uses DE3022 bulb.
2002 Mitsubishi Eclipse Instrument-general uses 74 bulb.
2003 Mitsubishi Eclipse Light Bulb Fitment Application List:
2003 Mitsubishi Eclipse High & low beam headlight uses 9003/HB2 bulb.
2003 Mitsubishi Eclipse Parking light uses 1157 bulb.
2003 Mitsubishi Eclipse Front turn signal uses 1157 bulb.
2003 Mitsubishi Eclipse Rear turn signal uses 1156 bulb.
2003 Mitsubishi Eclipse Tail light uses 2057 bulb.
2003 Mitsubishi Eclipse Stop light uses 2057 bulb.
2003 Mitsubishi Eclipse High mount stop light uses 921 bulb.
2003 Mitsubishi Eclipse Fog/Driving light uses H1 bulb.
2003 Mitsubishi Eclipse License plate uses 168 bulb.
2003 Mitsubishi Eclipse Back up light uses 1156 bulb.
2003 Mitsubishi Eclipse Front sidemarker uses 1157 bulb.
2003 Mitsubishi Eclipse Rear sidemarker uses 168 bulb.
2003 Mitsubishi Eclipse Dome light uses 562 bulb.
2003 Mitsubishi Eclipse Trunk/Cargo area uses DE3022 bulb.
2004 Mitsubishi Eclipse Light Bulb Fitment Application List:
2004 Mitsubishi Eclipse High & low beam headlight uses 9003/HB2 bulb.
2004 Mitsubishi Eclipse Parking light uses 1157 bulb.
2004 Mitsubishi Eclipse Front turn signal uses 1157 bulb.
2004 Mitsubishi Eclipse Rear turn signal uses 1156 bulb.
2004 Mitsubishi Eclipse Tail light uses 2057 bulb.
2004 Mitsubishi Eclipse Stop light uses 2057 bulb.
2004 Mitsubishi Eclipse High mount stop light uses 921 bulb.
2004 Mitsubishi Eclipse Fog/Driving light uses H1 bulb.
2004 Mitsubishi Eclipse License plate uses 168 bulb.
2004 Mitsubishi Eclipse Back up light uses 1156 bulb.
2004 Mitsubishi Eclipse Front sidemarker uses 1157 bulb.
2004 Mitsubishi Eclipse Rear sidemarker uses 168 bulb.
2004 Mitsubishi Eclipse Dome light uses 562 bulb.
2004 Mitsubishi Eclipse Trunk/Cargo area uses DE3022 bulb.
2005 Mitsubishi Eclipse Light Bulb Fitment Application List:
2005 Mitsubishi Eclipse High & low beam headlight uses 9003/HB2 bulb.
2005 Mitsubishi Eclipse Parking light uses 1157 bulb.
2005 Mitsubishi Eclipse Front turn signal uses 1157 bulb.
2005 Mitsubishi Eclipse Rear turn signal uses 1156 bulb.
2005 Mitsubishi Eclipse Tail light uses 2057 bulb.
2005 Mitsubishi Eclipse Stop light uses 2057 bulb.
2005 Mitsubishi Eclipse High mount stop light uses 921 bulb.
2005 Mitsubishi Eclipse Fog/Driving light uses H1 bulb.
2005 Mitsubishi Eclipse License plate uses 168 bulb.
2005 Mitsubishi Eclipse Back up light uses 1156 bulb.
2005 Mitsubishi Eclipse Front sidemarker uses 1157 bulb.
2005 Mitsubishi Eclipse Rear sidemarker uses 168 bulb.
2005 Mitsubishi Eclipse Dome light uses 562 bulb.
2005 Mitsubishi Eclipse Trunk/Cargo area uses DE3022 bulb.
the link to this is
2000-2005 Mitsubishi Eclipse Light Bulb Fitment Application List | Dash Z Racing Blog
Bulb Size Chart
Courtesy of various other members, and of course, our owner's manual:
Headlights (2) - H4 / HB2 / 9003
Foglights (2) - H3
Clock pod (3), temp controls (2), cubby hole (1) - 74
Gauges (6), rear corners (2) - 194
Rearview mirror (2) - Festoon 214-2 (44x10mm)
Front side markers (2) - 1157
Reverse (backup) lights (2), Rear turn signal light (2) - 1156
Third brake light (1) - 921
Trunk (1) - T-6 / H-223 / Festoon 3022 (31x10mm)
Rear side markers (2), license plate (1) - 168
Dome light - 168 WEDGE bulb
Stop and tail light (2) - 2057
2003-2005
Foglights (2) - H1
Foglights (2) - H3
2003-2005
Foglights (2) - H1
I need to know the bulb sizes for 2000 gt please
