My engine on my v6 eclipse would bog down and just shut off on idle when I have the heater on full blast and idk what would be the reason why I’m still kinda new to the car community help would be appreciated if you had the same problem and fixed it lmk I need some feedback please.
Super Moderator
That seems very odd. So you say this only happens when the heater is on. Maybe the heater is drawing too much power and your alternator can't keep up? That would be my guess.
oh okay I’ll look in to that thank you I’ll lyk if that’s the problem.
2005 Spyder GT
bring the car to autozone or somewhere that will test your alternator for voltage output before and after load. Alternator voltage output should remain above 13volts under load (with blower on). If it doesn't, first check and clean alternator connections BEFORE buying a new alternator.
