2001 eclipse GT
Heres the series of events...
passenger headlight stopped working.
replaced both bulbs, still not working.
found out the wire that was crimped was done poorly, and came loose.
I crimped one, didnt see the other that had also come apart (either when I was fixing other or same time as other idk)
So, I drove around a while, and when turining on brights, the passenger headlight just turned off. The hazards/turn signals stopped working after letting it go a while(shame on me!). It is not the bulbs, and not sure if it relates to the main issue.
Now, knew something was still wrong, thats when I found and crimped the other wire.
Now headlights work how they should. I pulled out every fuse under hood and passenger box, they all looked ok to me. I swapped some around of the same Amperage to see if I could get the hazards working. No luck. And now the car wont start. Battery is fine, even jumped it.
When trying to start, it ticks, kind of like a bad starter but way quieter and sounds like its coming from fuse box under the hood. Maybe a relay? I didnt take any of those out. I think it was probably a fuse somewhere that went bad and just doesnt look it, and maybe it was one I swapped.
Any ideas?
Any ideas?
