1 - 1 of 1 Posts
Okay, so I can't find my spacifice problem on here. I'm going to be as detailed as I can so nobody gets this mixed up. I have a 2002 mitsubishi eclipse GT 3.0V 6 with a 5 speed. The negative battery terminal cable is dicked, over half the wires are cut on the ground wire and it has a poor connection. I know that's a problem with these cars though. As of recently the cars lights will get dim and when I try to start it they shut off immediately, I ended up running a new wire from the terminal to the strut tower area. Then the lights started flickering the ECU was turning off and on fast as fuck boi. The positive battery cable was never detached throughout the negative battery cable switcheroo, now after a little while of trying to start and fiddle with the cable, nothing works on the car. No lights or anything. I reattached the old negative battery cable and still, nothing is working. Is this I've owned this car for about 3 months, is this piece of shit dead or is it an easy fix?
1 - 1 of 1 Posts
