I already bought an exedy clutch, and now I need to get a flywheel also. The oem flywheel is about 250 or more. I found some on ebay non oem for 150. If anyone can help. Is it necessary to go with oem?
Get your old one resurfaced. It is much cheaper. Or, for performance, I bought a lightweight fidanza flywheel and I am very happy with it. If it is just a daily driver, go OEM. I would not go cheap when it goes to tranny parts because if you aren't doing it yourself it is $600+ for labor. Cheap parts are not as reliable.
So I have to go with a new flywheel. My question is if it comes with the flex plate and new bolts or do you have to buy separate?
Manual transmissions do not have flex plates. Those are for automatic transmissions. I am not sure if the flywheel comes with new flywheel bolts. I know new Fidanzas do, but not sure of anything else.
I bought these and they worked perfectly for my fidanza flywheel:
OEM NEW Ford Racing Mustang GT 4.6L Manual Flywheel Bolts M6379B N808969S100 | eBay (https://www.ebay.com/itm/251617285312)
Hey, I know this is a fairly old thread but I need help. I am change my clutch out (using an Exedy clutch kit) and I want to replace my flywheel (not resurface it). Where can you get a new OEM flywheel? I cannot find one anywhere!
