A chassis Lube is a bit of BS now. Older cars used to have several grease fittings, especially in the days of parallelogram steering (instead of a rack and pinion) and when cars had upper and lower ball joints.
Most things on cars are sealed now with the exception of some componenets on SUV's and trucks. On my car, my sway bar links, tie rod ends and ball joints are all aftermarket from MOOG so they have grease fittings on them. Theoretically, being able to lube them should make them last longer, because even if water seeps in its no big deal, I can just flush out all the grease.
Hope this helps
Jim
Hope this helps
Jim
