Check Engine Light On. Help!
2197 Views 8 Replies 5 Participants Last post by  citm2000
I have a 2000 gt 5spd fed spec, and just last week my check engine light poped on. I have found out it is throwing P0420. It said Catalyst Efficiency Below Threshold (Bank 1). I was wondering what you have to do to get this fixed. I do have skunk 2 cat back and then a high flow cat.
Chad
1 - 9 of 9 Posts
CHeck your EGR valve if its clogged perhaps. Its behind by the intake manifold. Clean it out and clear the code and see what happens.
On a side note, it maybe a bad batch of Gasoline as well. Get some 93 Octane and run it through the system. It could also be that the cat is not clean the hydrocarbons well enough and the O2 sensors are picking it up.
Alright will do and i'll see what happens
Chad
It came back on, usually it is off for about a day or so and then pops back on.
Chad
any luck? I am having trouble with the same code.
It might just be an O2 sensor. Mine is on its been on for over a year. Go to Advance auto parts or Auto zone they will scan it for free. but might just be a 02 heater burnt out.
I have a 2002 Dodge Stratus R/T.
I had the code read... P0421: Warm Up Catalyst Efficiency Below Threshold (Bank 1) and P0431: Warm Up Catalyst Efficiency Below Threshold (Bank 2)
Could it be a bad sensor or am I going to have to replace the front two cats?? I just had the rear replaced by an aftermarket type. The dodge part was huge and expensive. I was told the fronts were very expensive. I dont want to replace if i dont have to.
Is there any way to know if the sensor is bad?
No -- there's a separate code for that.
My advice: If you don't want to replace your pre-cats, do the anti-fouler trick.
1 - 9 of 9 Posts
